Hi Andrew,
I added something to the Release Notes. I believe the version should be 6.0.0 because servers using the new version and relying on a less strict compatibility check might break clients using the old, more strict version.
ntCPP.html seems to be an overview of the public interface, which was not changed, so I didn't touch it. I can take a deeper look at it on Monday to see if I can just bump the date on it.
Hi Bruno,
I'm currently working on generating a new EPICS release, and I just noticed that there is nothing in the normativeTypes Release Notes document about all of the updates you made to the validation code back in May and June. Would you have any time in the next
working day or so to add some notes about your changes to the top of the documentation/RELEASE_NOTES.md file?
I will need to bump the module's version number from 5.2.2; after your changes, should this become 6.0.0 or would 5.3.0 be a better choice? You could just answer that question in Release notes heading you use if you like.
I suspect the file documentation/ntCPP.html may also need some changes to match your updates. I'm not expecting you to work on that at the same time, but I'd appreciate if you could take a quick look at it and assess how much it might need to be modified. If
the changes are trivial and you can do them that would be great, but if not please just include a comment in the Release Notes that the other document has not been updated yet (it already shows an older version and date).
Sorry this request is a bit last-minute.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: normativeTypes module in EPICS 7.0.3 Johnson, Andrew N. via Core-talk
- normativeTypes module in EPICS 7.0.3 Johnson, Andrew N. via Core-talk
Re: epics base compilation for ARM Cotex-A53 (ARM64bit) Johnson, Andrew N. via Core-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 26 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
