2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1839657] [NEW] Unhelpful MSI error message and behaviour
To: [email protected]
Date: Fri, 09 Aug 2019 18:23:52 -0000
Public bug reported:
msi was acting up  on a new application I was developing.    When I ran make in my support module Db source directory I got:
wenorum@xildev4 488> make
perl -CSD /eda/epics/R3.15.5/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/home/lxusers/w/wenorum/src/siocPowerSupplyPWM/powerSupplyPWMSup/Db/O.linux-x86_64'
/eda/epics/R3.15.5/base/bin/linux-x86_64/msi -D    -I. -I.. -I../O.Common -I../../../db -I/eda/epics/R3.15.5/modules/instrument/QF2preMonitor/head/db -I/eda/epics/R3.15.5/modules/soft/asyn/asyn4-31/db -I/eda/epics/R3.15.5/modules/soft/autosave/autosave-5-8/db -I/eda/epics/R3.15.5/modules/soft/iocExit/iocExit-2-0/db -I/eda/epics/R3.15.5/base/db -o ../O.Common/powerSupplyPWMSup.db -S../powerSupplyPWMSup.substitutions  > powerSupplyPWMSup.db.d
msi: No template file
Usage: msi [options] [template]
  stdin is used if neither template nor substitution file is given
  options:
    -h        Print this help message
    -D        Output file dependencies, not substitutions
    -V        Undefined macros generate an error
    -g        All macros have global scope
    -o<FILE>  Send output to <FILE>
    -I<DIR>   Add <DIR> to include file search path
    -M<SUBST> Add <SUBST> to (global) macro definitions
              (<SUBST> takes the form VAR=VALUE,...)
    -S<FILE>  Expand the substitutions in FILE
Inflating database from ../powerSupplyPWMSup.substitutions
/eda/epics/R3.15.5/base/bin/linux-x86_64/msi    -I. -I.. -I../O.Common -I../../../db -I/eda/epics/R3.15.5/modules/instrument/QF2preMonitor/head/db -I/eda/epics/R3.15.5/modules/soft/asyn/asyn4-31/db -I/eda/epics/R3.15.5/modules/soft/autosave/autosave-5-8/db -I/eda/epics/R3.15.5/modules/soft/iocExit/iocExit-2-0/db -I/eda/epics/R3.15.5/base/db -o powerSupplyPWMSup.db -S../powerSupplyPWMSup.substitutions
  options:
make[1]: *** [../O.Common/powerSupplyPWMSup.db] Error 1
make[1]: Leaving directory `/home/lxusers/w/wenorum/src/siocPowerSupplyPWM/powerSupplyPWMSup/Db/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
wenorum@xildev4 489>
But the msi runs seemed to have succeeded:
wenorum@xildev4 489> ls O.linux-x86_64/
Makefile  powerSupplyPWMSup.db  powerSupplyPWMSup.db.d
Running msi again produced a .db file in the support module <TOP>/db/ directory.
The problem was an extra closing brace in the substitutions file:
wenorum@xildev4 491> cat powerSupplyPWMSup.substitutions
file "perFPGA.template"
{ pattern
{    P,      R,      PORT  }
{"\$(P)","\$(R)","\$(PORT)" }
file "perBridge.template"
{ pattern
{    P,      R,      PORT,   C }
{"\$(P)","\$(R)","\$(PORT)", 0 }}
So the error was in my code, but the error message produced by msi was pretty unhelpful.  Something like “powerSupplyPWMSup.substitutions:10 — syntax error" would have been a lot more useful.  Also it would probably be better if msi  and/or the make system could remove any output file when the source contains syntax errors.
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1839657
Title:
Status in EPICS Base:
  New
Bug description:
  mkdir O.Common
    options:
    options:
  { pattern
  {    P,      R,      PORT  }
  { pattern
  {    P,      R,      PORT,   C }
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1839657/+subscriptions
Prev: Re: Strange logging behavior in EPICS 7 on vxWorks Zimoch Dirk (PSI) via Core-talk
Next: Build failed in Jenkins: epics-pvaPy-linux32 #783 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
