2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: pvget hangs
From: Mark Rivers via Core-talk <[email protected]>
Date: Tue, 13 Aug 2019 21:39:25 +0000
I had a problem with pvget today.
I am running an areaDetector IOC that runs qsrv and also the NDPluginPva.  The IOC is running 7.0.3, linux-x86_64 on Ubuntu 18.
On this IOC this is the output of pvasr:
epics> pvasr
pvAccess Server v7.0.0
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = QSRV local
I try to access a PV using caget, pvget –p ca, and pvget –p pva.  I am using the 7.0.3 versions of all of these.  These are running on the same Ubuntu 18 machine as the IOC.
caget works fine.
TahoeU18:/corvette/home/epics/devel/areaDetector/configure> /corvette/usr/local/epics-devel/base-7.0.3/bin/linux-x86_64-ub18/caget 13SP1:cam1:AcquireTime
13SP1:cam1:AcquireTime         0.001
pvget –p ca works fine.
TahoeU18:/corvette/home/epics/devel/areaDetector/configure> /corvette/usr/local/epics-devel/base-7.0.3/bin/linux-x86_64-ub18/pvget -p ca 13SP1:cam1:AcquireTime
pvget –p pva prints a timeout message, and then the program hangs.  The only way to kill it is with “kill -9” from another terminal.
TahoeU18:/corvette/home/epics/devel/areaDetector/configure> /corvette/usr/local/epics-devel/base-7.0.3/bin/linux-x86_64-ub18/pvget -p pva 13SP1:cam1:AcquireTime
Timeout
^C^C^C^C
Killed
I tried running the pvget –p pva command on another Linux system (Centos 7, base 7.0.3), talking to the same IOC.  It also hung up the same way, I had to kill it with -9.
The IOC appeared to be working fine in all other respects.
I then rebooted the IOC and the problem with pvget –p pva is gone.
13SP1:cam1:AcquireTime 2019-08-13 16:15:10.742  0.001
Any idea what could have been wrong that rebooting fixed?
Re: pvget hangs Michael Davidsaver via Core-talk
Prev: Jenkins build is back to normal : epics-example-linux32 #706 APS Jenkins via Core-talk
Next: Re: Possible bug in pvput and mbbi records Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-pva2pva-linux32 #132 APS Jenkins via Core-talk
Next: Re: pvget hangs Michael Davidsaver via Core-talk
ANJ, 13 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
