2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
To: mdavidsaver <[email protected]>
Date: Wed, 14 Aug 2019 05:59:34 -0000
Successfully tested this patch w/ pvAccess gwdev branch and pva2pva d7314ea from mdavidsaver.
Tested IOC and ca-gateway instances w/ asCheckClientIP=0 and asCheckClientIP=1.
ca-gateway was based on R2-1-1-0 with inline code to set asCheckClientIP.
No changes were needed to pcas version 4.13.2.
With asCheckClientIP=0, a hacked caput can bypass ASG RULES using hostnames.
With asCheckClientIP=1, caput can only spoof username
For pvput and IOC testing:
With asCheckClientIP=0, All ASG RULES using HAG deny write access.
With asCheckClientIP=1, pvput works same as CA for all UAG and HAG based ASG RULES.  (Didn't test variables in RULES or spoofing username in pvput.)
Also tested w/ new p4p gateway as a client while p4p gateway is running it's own access security.
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Jenkins build is still unstable: epics-7.0 » mac #142 APS Jenkins via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Bruce Hill via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 14 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
