2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
To: mdavidsaver <[email protected]>
Date: Wed, 14 Aug 2019 06:10:31 -0000
Re the initial default for asCheckClientIP, I recommend it be set to 1.
Defaulting to 0 only helps those who run w/o DNS yet also want to run EPICS 7 IOCs
but continue to use CA instead of PVA to modify their access secured PVs.
They also have an easy workaround by using IP addr in their acf files.
Meanwhile, every site who tries to support access security w/ EPICS 7 could easily
miss the need to set asCheckClientIP in order to make pvAccess support HAG based rules.
It also has the benefit of closing the CA spoofed hostname vulnerability.
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Ernest Williams via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Bruce Hill via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Ernest Williams via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 14 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
