Subject: |
Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 |
Ernest Williams via Core-talk <[email protected]> |
To: |
Bruce Hill <[email protected]> |
Date: |
Wed, 14 Aug 2019 06:39:21 -0000 |
I agree
Sent from my iPhone
> On Aug 13, 2019, at 11:10 PM, Bruce Hill via Core-talk <[email protected]> wrote:
> Re the initial default for asCheckClientIP, I recommend it be set to 1.
> Defaulting to 0 only helps those who run w/o DNS yet also want to run EPICS 7 IOCs
> but continue to use CA instead of PVA to modify their access secured PVs.
> They also have an easy workaround by using IP addr in their acf files.
> Meanwhile, every site who tries to support access security w/ EPICS 7 could easily
> miss the need to set asCheckClientIP in order to make pvAccess support HAG based rules.
> It also has the benefit of closing the CA spoofed hostname vulnerability.
> https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
> Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Bruce Hill via Core-talk
Build failed: EPICS Base base-7.0-421 AppVeyor via Core-talk
<2019>
2025
2026
Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
<2019>
2025
2026
