2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Thu, 22 Aug 2019 20:49:30 -0000
Review: Approve
Minor Q: An IPv4 address represented as an ASCII dotted-quad needs no more than 16 chars including the string terminator. Why are you (consistently) allocating 24? With a port number it would need 22 chars, and 24 chars would be too short for an IPv6 address. Just wondering...
On the default value of asCheckClientIP, my concern with making it 1 is that this could change the behavior for some existing working systems. If the name for a client listed in an IOC's ASCF is the canonical hostname for the client machine but the network path to that IOC comes through a secondary network interface with a different DNS name, a previously working ASCF rule will now deny access to that client. Admittedly this is an unusual situation but it's by no means impossible, and the code currently has no way to detect when it happens (it could, but Michael has better things to do with his time than implement that). If we do change the default the release notes would need changing to match, and they should probably have something in bold or red to get people to notice.
Approved.
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Jenkins build is back to normal : EPICS-3.14 #404 Jenkins EPICS PSI via Core-talk
Next: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Ernest Williams via Core-talk
ANJ, 22 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
