2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Strange behavior of async calcout with CPP input link
From: Benjamin Franksen via Core-talk <[email protected]>
To: EPICS Core-Talk <[email protected]>
Date: Mon, 26 Aug 2019 18:46:23 +0200
I am using base-3.15.6. This is a part of a larger database, running on
a soft IOC on Linux:
record(calc,"DEV1:st") {
    # the field details are irrelevant here,
    # just note this is a simple soft record
    # that gets processed via CPP input links
    field(INPA,"DEV1:stZ CPP")
    field(INPB,"DEV1:stS CPP")
    field(CALC,"A<<4|B&0xf")
record(calcout,"DEV1:trgOn") {
    field(INPA,"DEV1:sel")
    # trigger processing on change of readback
    field(INPB,"DEV1:st CPP")
    field(CALC,"A==B")
    field(DOPT,"Transition to non-zero")
    field(DTYP,"Async Soft Channel")
    field(OUT,"DEV2:switch CA")
The values involved are all integers.
DEV1:sel is the setpoint, DEV1:st is the (soft) readback, which gets
triggered by writing DEV1.sel via a chain of FLNKs, OUT PP links and CPP
input links. The idea is to write a "1" to the DEV2:switch (which is a
different device controlled by another IOC) when the readback has
settled to the same value as the setpoint. The device DEV1 is complex
and requires various separate commands to effect the change, and the
readback can go through 2 or 3 different values before finally
coinciding with the setpoint.
When I set DEV1:sel (using caput) to different values, I can sometimes
get into a situation where the database has the following (persistent)
state:
DEV1:sel.VAL=0
DEV1:st.VAL=0
DEV1:trgOn.A=0
DEV1:trgOn.B=8
DEV1:trgOn.VAL=0
I think this should not be possible, assuming that
(1) the value of the last monitor event (here: from DEV1:st) always wins
    over previous events, and
(2) if a record (here: DEV1:trgOn) is active (PACT=1) when an event
    arrives, it gets processed again, after completing.
Either this is a bug or at least one of my assumptions is wrong. I
wonder which.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Strange behavior of async calcout with CPP input link Michael Davidsaver via Core-talk
Prev: Build failed: epics-base base-iocsherr-283 AppVeyor via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Strange behavior of async calcout with CPP input link Michael Davidsaver via Core-talk
ANJ, 26 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
