2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 02 Sep 2019 08:41:40 -0000
Same patch for pvDatabase submodule
** Patch added: "Makes xxxTestHarness TESTPRODs instead of PRODs"
   https://bugs.launchpad.net/epics-base/+bug/1842086/+attachment/5286170/+files/TESTPROD_pvDatabase.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1842086
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  Several "TestHarness" vxWorks and RTEMS products are built as
  PROD_vxWorks and PROD_RTEMS instead of TESTPROD_vxWorks and
  TESTPROD_RTEMS even though they depend on TESTLIB code. This seems a
  bit inconsistent. Changing them to TESTPROD would allow to build EPICS
  base without tests, which could speed up the development cycle in an
  early phase when building the tests is not yet needed.
  Attached is a patch for EPICS 7 base. The same could be done for the
  submodules.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842086/+subscriptions
[Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Prev: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Next: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 02 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
