2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 30 Aug 2019 14:51:53 -0000
Public bug reported:
Several "TestHarness" vxWorks and RTEMS products are built as
PROD_vxWorks and PROD_RTEMS instead of TESTPROD_vxWorks and
TESTPROD_RTEMS even though they depend on TESTLIB code. This seems a bit
inconsistent. Changing them to TESTPROD would allow to build EPICS base
without tests, which could speed up the development cycle in an early
phase when building the tests is not yet needed.
Attached is a patch for EPICS 7 base. The same could be done for the
submodules.
** Affects: epics-base
     Importance: Undecided
         Status: New
** Patch added: "Makes xxxTestHarness TESTPRODs instead of PRODs"
   https://bugs.launchpad.net/bugs/1842086/+attachment/5285801/+files/TESTPROD_base.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
Title:
Status in EPICS Base:
  New
Bug description:
  bit inconsistent. Changing them to TESTPROD would allow to build EPICS
  base without tests, which could speed up the development cycle in an
  early phase when building the tests is not yet needed.
  submodules.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842086/+subscriptions
[Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Andrew Johnson via Core-talk
[Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Prev: Re: pvPutLog? Michael Davidsaver via Core-talk
Next: [Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvPutLog? Johnson, Andrew N. via Core-talk
Next: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Andrew Johnson via Core-talk
ANJ, 01 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
