2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvPutLog?
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 30 Aug 2019 07:01:29 -0700
On 8/30/19 6:49 AM, Zimoch Dirk (PSI) wrote:
> On Fri, 2019-08-30 at 06:36 -0700, Michael Davidsaver wrote:
>> On 8/30/19 5:06 AM, Zimoch Dirk (PSI) via Core-talk wrote:
>>> Hello,
>>> I think Timo's question boils down to: Does Channel Access Security work with PVA?
>>> And according to my quick test the answer is "No".
>>> So at the moment if you cannot write with caput because the access is read-only, simply use pvput and you can.
>> https://github.com/epics-base/pva2pva/pull/29
>> How can I help you, and the other core-talk subscribers reading this,
>> engage more with in progress development?
> Is there a page which summarizes all in progress development?
Yes, well two pages.  Subscribing to interesting repositories on LP and github
is also a good way to see what is happening.  Neither is (unfortunately) high
traffic at this point.
https://github.com/pulls?utf8=%E2%9C%93&q=is%3Aopen+is%3Apr+archived%3Afalse+user%3Aepics-base+
https://code.launchpad.net/epics-base/+activereviews
Re: pvPutLog? Timo Korhonen via Core-talk
Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Re: pvPutLog? Michael Davidsaver via Core-talk
Prev: Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Next: [Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: pvPutLog? Timo Korhonen via Core-talk
ANJ, 30 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
