2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 01 Nov 2019 20:31:15 -0000
These patches should have been applied for this release, sorry this fell
through the cracks.
** Changed in: epics-base/7.0
    Milestone: 7.0.3.1 => 7.0.3.2
     Assignee: (unassigned) => Andrew Johnson (anj)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1842086
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  Several "TestHarness" vxWorks and RTEMS products are built as
  PROD_vxWorks and PROD_RTEMS instead of TESTPROD_vxWorks and
  TESTPROD_RTEMS even though they depend on TESTLIB code. This seems a
  bit inconsistent. Changing them to TESTPROD would allow to build EPICS
  base without tests, which could speed up the development cycle in an
  early phase when building the tests is not yet needed.
  Attached is a patch for EPICS 7 base. The same could be done for the
  submodules.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842086/+subscriptions
[Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Prev: [Bug 1730982] Re: Race in db_close_events() Andrew Johnson via Core-talk
Next: [Bug 1845854] Re: EPICS Math tests failing on Windows with MSVC Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Next: Jenkins build became unstable: epics-7.0 » linux32 #144 APS Jenkins via Core-talk
ANJ, 01 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
