Hi Michael,
> On Sep 4, 2019, at 4:45 AM, Michael Davidsaver <[email protected]> wrote:
> https://github.com/epics-modules/caPutLog/blob/b544f92c6efe1df98506b567f3f7e5137965e2a4/caPutLogApp/caPutLogAs.c#L104
> dbGetField() is used, which of course calls dbScanLock().
> This is done twice, for the "before" and "after" values.
> So 'pmessage->data' is not used.
> I guess I can just pass data=NULL or a dummy value.
Please look at commit c5ded30684 in Base. The asTrapWrite.h API was enhanced about 4 years ago in 3.15 and caPutLog is no longer the only external user of it. Tim Mooney's caPutRecorder module *does* rely on pmessage->data. Direct access to the data was added on his request, so he can record exactly what value was put even if the record processing subsequently modifies that field value (puts to the Motor record can fall into that category).
Someone could modify caPutLog to make use of the data field instead of calling dbGetField() twice.
- Andrew
- pvPutLog? Timo Korhonen via Core-talk
- Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
- Re: pvPutLog? Michael Davidsaver via Core-talk
- Re: pvPutLog? Timo Korhonen via Core-talk
- Re: pvPutLog? Johnson, Andrew N. via Core-talk
Build failed in Jenkins: epics-example-vx69 #418 APS Jenkins via Core-talk
Build failed in Jenkins: epics-example-vx68 #419 APS Jenkins via Core-talk
<2019>
2025
2026
[Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
<2019>
2025
2026
