2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvPutLog?
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Zimoch Dirk (PSI)" <[email protected]>
Date: Mon, 2 Sep 2019 08:57:12 -0700
The main concern I see is locking and callbacks.  Current calls to asTrap*() happen
without holding the record lock.  The asTrap* functions can't be moved entirely into
dbChannelPut() without changing this.
This concern is also why I can't trivially add asTrap*() calls to QSRV.  The PVA to DBR
data type conversion is currently happening under the record lock.  (Not required,
just convenient)
If this were to change then some answer/plan would need to be made to address the
possibility of deadlocks and slowdown.  Maybe it is enough to say that asTrap handlers
should never be locking records or blocking?
Also, I hadn't noticed asTrapWritePvt::lock before.  So many singleton locks...
On 9/2/19 4:39 AM, Johnson, Andrew N. wrote:
> I don’t think that would be trivial even for just the Trap Write calls, the dbChannel layer doesn’t have access to the asClientPVT context pointer. For the other interfaces dbChannel doesn’t know anything about the client that is requesting access. I suspect the current arrangement may be the simplest, but I haven’t looked at it too closely.
> - Andrew
>> On Sep 2, 2019, at 9:08 AM, Zimoch Dirk (PSI) via Core-talk <[email protected]> wrote:
>> On Mon, 2019-09-02 at 07:00 +0000, Zimoch Dirk (PSI) via Core-talk wrote:
>>> Shouldn't PVA be implemented one level lower in dbChannel instead of in each network protocol?
>> Sorry typo, I meant: Shouldn't access security be implemented in dbChannel?
>> Dirk
Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
pvPutLog? Timo Korhonen via Core-talk
Re: pvPutLog? Michael Davidsaver via Core-talk
Re: pvPutLog? Timo Korhonen via Core-talk
Re: pvPutLog? Johnson, Andrew N. via Core-talk
Prev: Jenkins build is back to stable : epics-7.0 » linux32 #145 APS Jenkins via Core-talk
Next: Build failed: epics-base base-7.0-289 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvPutLog? Johnson, Andrew N. via Core-talk
Next: Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
ANJ, 03 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
