2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: pvPutLog?
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Sep 2019 11:39:45 +0000
I don’t think that would be trivial even for just the Trap Write calls, the dbChannel layer doesn’t have access to the asClientPVT context pointer. For the other interfaces dbChannel doesn’t know anything about the client that is requesting access. I suspect the current arrangement may be the simplest, but I haven’t looked at it too closely.
- Andrew
> On Sep 2, 2019, at 9:08 AM, Zimoch Dirk (PSI) via Core-talk <[email protected]> wrote:
> On Mon, 2019-09-02 at 07:00 +0000, Zimoch Dirk (PSI) via Core-talk wrote:
>> Shouldn't PVA be implemented one level lower in dbChannel instead of in each network protocol?
> Sorry typo, I meant: Shouldn't access security be implemented in dbChannel?
> Dirk
Re: pvPutLog? Michael Davidsaver via Core-talk
pvPutLog? Timo Korhonen via Core-talk
Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Re: pvPutLog? Timo Korhonen via Core-talk
Prev: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Next: Jenkins build is back to stable : epics-base-3.15-test #124 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Next: Re: pvPutLog? Michael Davidsaver via Core-talk
ANJ, 02 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
