2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 30 Aug 2019 20:21:11 -0000
When we first started running the libCom tests on VxWorks I found it
useful for the test harness munch file to be installed into the
bin/<arch> directory instead of buried somewhere inside the source tree.
This is no longer as advantageous since the tests now depend on various
other files (mostly .dbd and .db) which are also spread around the
source tree (although maybe not quite as much), so I have to cd around
the tree anyway to be able to run them.
We don't currently have a way to build Base without also building the
tests, but that's actually a completely orthogonal issue. If we wanted
that I would probably implement it by adding a TEST_DIRS variable
(analogous to DIRS) and only descend into those directories when
actually building tests. We only have one TESTPROD being built in a non-
test directory at the moment:
Entering 'pva2pva'
p2pApp/Makefile:TESTPROD_HOST += testmon
** Changed in: epics-base
       Status: New => In Progress
   Importance: Undecided => Low
** Also affects: epics-base/7.0
   Importance: Low
       Status: In Progress
** Changed in: epics-base/7.0
    Milestone: None => 7.0.3.1
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1842086
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  Several "TestHarness" vxWorks and RTEMS products are built as
  PROD_vxWorks and PROD_RTEMS instead of TESTPROD_vxWorks and
  TESTPROD_RTEMS even though they depend on TESTLIB code. This seems a
  bit inconsistent. Changing them to TESTPROD would allow to build EPICS
  base without tests, which could speed up the development cycle in an
  early phase when building the tests is not yet needed.
  Attached is a patch for EPICS 7 base. The same could be done for the
  submodules.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842086/+subscriptions
[Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Prev: [Bug 1841634] Re: CP link triggers lost when record is async Andrew Johnson via Core-talk
Next: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 noreply--- via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1842086] [NEW] TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
Next: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Dirk Zimoch via Core-talk
ANJ, 02 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
