2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1841634] Re: CP link triggers lost when record is async
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 30 Aug 2019 18:43:14 -0000
Okay, so that part of dbCa changed in 3.16 without my realizing it, I
was looking at the 3.15 version and had forgotten about the
scanLinkOnce() addition, sorry my bad.
So now we need to have a discussion on whether updates from CA links
with CP/CPP set should queue or cache. Maybe there could be another flag
in the link to request queueing, but given that the CA event queues
sending the value updates can and do throw away older updates once the
queue is full I think we're better off not allowing multiple triggers to
get queued up. The dbCa code doesn't queue the values, so I see little
point in processing the record more than once after the last trigger has
arrived and its value cached. We need to ensure that the record does
process once after the last update, but I don't think we could wait for
the dbNotify "finished" event. That might not happen until hours later
in some cases, so I think it would be the wrong mechanism.
RPRO could do what we need if we had a way to get onceTask to do
something different. How about we modify onceTask to give it a more
general callback mechanism as well. It should still use the ring buffer,
but maybe push variable length items to avoid wasting ring space (the
push operation must be atomic, but the pulls don't need to be). A call
to scanOnce() with no callback only needs to push a "process this
record" command and the record pointer; a call to scanOnceCallback()
needs to push "process record and callback" plus the three pointer
arguments; we'd add a generic "call this" command with 2 pointer
arguments.
With this the dbCa callback would lock the record, process it or set
RPRO and unlock with completion checks that we need. The scanningOnce
counter could become a boolean but in any case it should be zeroed in
dbCaGetLink(), which is the point at which we'll have passed the latest
cached value to the record so the trigger from it can expire. We no
longer have a queue with an arbitrary length, and we don't process the
record more than necessary.
Does that finally make some sense?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841634
Title:
Status in EPICS Base:
  Confirmed
Status in EPICS Base 7.0 series:
  Confirmed
Bug description:
  From Benjamin Franksen:
  Here is a small self-contained database to reproduce this:
  record(calcout,"input") {
      field(CALC,"A<4?A+1:A")
      field(INPA,"input")
      field(ODLY,"1")
      field(OUT,"input.A CA")
  record(calcout,"output") {
      field(ODLY,"1.5")
      field(INPA,"input CPP")
      field(CALC,"A")
      field(TPRO,1)
  record(calc,"check") {
      field(INPB,"output CPP")
      field(CALC,"A==B")
  Processing "input" (caput input.PROC 1) starts the test. The "check"
  record should eventually settle to 1 (but doesn't).
  With 7.0.3 I get this output:
  scanOnce: dbProcess of 'output' # initial CPP processing
  scanOnce: dbProcess of Active 'output' with RPRO=0
  Note how this says "with RPRO=0".
  And camonitor says:
  franksen@tiber: ~ > camonitor input output check
  input                          <undefined> 0 UDF INVALID
  output                         2019-08-27 16:02:16.106413 0
  check                          2019-08-27 16:02:16.106617 1
  input                          2019-08-27 16:02:26.498483 1
  check                          2019-08-27 16:02:26.498721 0
  input                          2019-08-27 16:02:27.493734 2
  output                         2019-08-27 16:02:27.993908 1
  input                          2019-08-27 16:02:28.489068 3
  input                          2019-08-27 16:02:29.484350 4
  output                         2019-08-27 16:02:29.984458 3
  I think the difference in behavior between processing due to a CPP
  input link versus processing due to a PP or CA output link is quite
  surprising.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841634/+subscriptions
[Bug 1841634] [NEW] CP link triggers lost when record is async Andrew Johnson via Core-talk
Prev: Re: pvPutLog? Michael Davidsaver via Core-talk
Next: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
Next: [Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
ANJ, 03 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
