2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1841634] [NEW] CP link triggers lost when record is async
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 27 Aug 2019 16:49:38 -0000
Public bug reported:
>From Benjamin Franksen:
Here is a small self-contained database to reproduce this:
record(calcout,"input") {
    field(CALC,"A<4?A+1:A")
    field(INPA,"input")
    field(ODLY,"1")
    field(OUT,"input.A CA")
record(calcout,"output") {
    field(ODLY,"1.5")
    field(INPA,"input CPP")
    field(CALC,"A")
    field(TPRO,1)
record(calc,"check") {
    field(INPB,"output CPP")
    field(CALC,"A==B")
Processing "input" (caput input.PROC 1) starts the test. The "check"
record should eventually settle to 1 (but doesn't).
With 7.0.3 I get this output:
scanOnce: dbProcess of 'output' # initial CPP processing
scanOnce: dbProcess of Active 'output' with RPRO=0
Note how this says "with RPRO=0".
And camonitor says:
franksen@tiber: ~ > camonitor input output check
input                          <undefined> 0 UDF INVALID
output                         2019-08-27 16:02:16.106413 0
check                          2019-08-27 16:02:16.106617 1
input                          2019-08-27 16:02:26.498483 1
check                          2019-08-27 16:02:26.498721 0
input                          2019-08-27 16:02:27.493734 2
output                         2019-08-27 16:02:27.993908 1
input                          2019-08-27 16:02:28.489068 3
input                          2019-08-27 16:02:29.484350 4
output                         2019-08-27 16:02:29.984458 3
I think the difference in behavior between processing due to a CPP
input link versus processing due to a PP or CA output link is quite
surprising.
** Affects: epics-base
     Importance: Wishlist
         Status: Confirmed
** Affects: epics-base/7.0
         Status: Confirmed
** Tags: codeathon
** Also affects: epics-base/7.0
       Status: Confirmed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841634
Title:
Status in EPICS Base:
  Confirmed
Status in EPICS Base 7.0 series:
  Confirmed
Bug description:
      field(INPA,"input")
      field(ODLY,"1")
      field(ODLY,"1.5")
      field(CALC,"A")
      field(TPRO,1)
      field(CALC,"A==B")
  And camonitor says:
  surprising.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841634/+subscriptions
[Bug 1841634] Re: CP link triggers lost when record is async Andrew Johnson via Core-talk
[Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
Prev: [Bug 1841608] Re: logClient falsely sends error logs on all connections Dirk Zimoch via Core-talk
Next: [Bug 1841634] Re: CP link triggers lost when record is async Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1841608] Re: logClient falsely sends error logs on all connections Martin Konrad via Core-talk
ANJ, 13 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
