2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1841634] Re: CP link triggers lost when record is async
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 29 Aug 2019 02:54:47 -0000
“a lot of churn”? — please explain.
I believe the rpro mechanism does exactly what we need here (but I admit
I was looking at the 3.15 version of the code, not 7.0). The scanOnce
code is pretty simple and short so duplicating it won’t be hard, the
only difference being that the queue processor checks pact and sets rpro
(and putf perhaps?) if needs be. The word Force isn’t quite right for
the API name though, I’ll keep thinking on that.
Why are you thinking we might have to introduce dbNotify here? Now
/that/ would be churn.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841634
Title:
Status in EPICS Base:
  Confirmed
Status in EPICS Base 7.0 series:
  Confirmed
Bug description:
  From Benjamin Franksen:
  Here is a small self-contained database to reproduce this:
  record(calcout,"input") {
      field(CALC,"A<4?A+1:A")
      field(INPA,"input")
      field(ODLY,"1")
      field(OUT,"input.A CA")
  record(calcout,"output") {
      field(ODLY,"1.5")
      field(INPA,"input CPP")
      field(CALC,"A")
      field(TPRO,1)
  record(calc,"check") {
      field(INPB,"output CPP")
      field(CALC,"A==B")
  Processing "input" (caput input.PROC 1) starts the test. The "check"
  record should eventually settle to 1 (but doesn't).
  With 7.0.3 I get this output:
  scanOnce: dbProcess of 'output' # initial CPP processing
  scanOnce: dbProcess of Active 'output' with RPRO=0
  Note how this says "with RPRO=0".
  And camonitor says:
  franksen@tiber: ~ > camonitor input output check
  input                          <undefined> 0 UDF INVALID
  output                         2019-08-27 16:02:16.106413 0
  check                          2019-08-27 16:02:16.106617 1
  input                          2019-08-27 16:02:26.498483 1
  check                          2019-08-27 16:02:26.498721 0
  input                          2019-08-27 16:02:27.493734 2
  output                         2019-08-27 16:02:27.993908 1
  input                          2019-08-27 16:02:28.489068 3
  input                          2019-08-27 16:02:29.484350 4
  output                         2019-08-27 16:02:29.984458 3
  I think the difference in behavior between processing due to a CPP
  input link versus processing due to a PP or CA output link is quite
  surprising.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841634/+subscriptions
[Bug 1841634] [NEW] CP link triggers lost when record is async Andrew Johnson via Core-talk
Prev: [Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
Next: Build failed: EPICS Base base-7.0-422 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: [Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
ANJ, 30 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
