2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 06 Sep 2019 12:13:04 -0000
It seems that the broken connection is quite reliably detected at the second send() after the connection had been closed. A dummy send(socket, NULL, 0, 0) seems sufficient to detect the broken connection to iocLogServer as well as to ncat and do Michael's server.py example.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Next: Build failed in Jenkins: epics-example-vx68 #418 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 06 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
