Subject: |
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 |
Dirk Zimoch via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 30 Aug 2019 07:21:24 -0000 |
Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0.
Commit message:
fix several problems in logClient
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Bugfix: don't send errlog to all logClients, only to iocLog
Improvements to minimize message loss when server disconnects:
* detect lost connection to server early
* do not discard buffer at disconnect
* flush buffer directly after reconnect
Other improvements:
* avoid delays on ioc startup and shutdown
* avoid repeated memmove
Relates to bug report #1841608
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0.
diff --git a/modules/libcom/src/log/iocLog.c b/modules/libcom/src/log/iocLog.c
index e62da20..8cb1349 100644
--- a/modules/libcom/src/log/iocLog.c
+++ b/modules/libcom/src/log/iocLog.c
@@ -18,8 +18,10 @@
#define epicsExportSharedSymbols
#include "envDefs.h"
+#include "errlog.h"
#include "logClient.h"
#include "iocLog.h"
+#include "epicsExit.h"
int iocLogDisable = 0;
@@ -75,6 +77,14 @@ void epicsShareAPI epicsShareAPI iocLogFlush (void)
+ * logClientDestroy()
+static void iocLogClientDestroy (logClientId id)
+ errlogRemoveListeners (logClientSendMessage, id);
* iocLogClientInit()
static logClientId iocLogClientInit (void)
@@ -89,6 +99,10 @@ static logClientId iocLogClientInit (void)
return NULL;
id = logClientCreate (addr, port);
+ if (id != NULL) {
+ errlogAddListener (logClientSendMessage, id);
+ epicsAtExit (iocLogClientDestroy, id);
return id;
diff --git a/modules/libcom/src/log/logClient.c b/modules/libcom/src/log/logClient.c
index 99ee671..0056a21 100644
--- a/modules/libcom/src/log/logClient.c
+++ b/modules/libcom/src/log/logClient.c
@@ -44,6 +44,7 @@ typedef struct {
SOCKET sock;
epicsThreadId restartThreadId;
epicsEventId stateChangeNotify;
+ epicsEventId shutdownNotify;
unsigned connectCount;
unsigned nextMsgIndex;
unsigned connected;
@@ -53,7 +54,6 @@ typedef struct {
} logClient;
static const double LOG_RESTART_DELAY = 5.0; /* sec */
-static const double LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT = 5.0; /* sec */
static const double LOG_SERVER_SHUTDOWN_TIMEOUT = 30.0; /* sec */
@@ -84,8 +84,6 @@ static void logClientClose ( logClient *pClient )
pClient->sock = INVALID_SOCKET;
- pClient->nextMsgIndex = 0u;
- memset ( pClient->msgBuf, '\0', sizeof ( pClient->msgBuf ) );
pClient->connected = 0u;
@@ -113,6 +111,7 @@ static void logClientDestroy (logClientId id)
epicsMutexMustLock ( pClient->mutex );
pClient->shutdown = 1u;
epicsMutexUnlock ( pClient->mutex );
+ epicsEventSignal ( pClient->shutdownNotify );
/* unblock log client thread blocking in send() or connect() */
interruptInfo =
@@ -154,13 +153,11 @@ static void logClientDestroy (logClientId id)
return;
- errlogRemoveListeners ( logClientSendMessage, (void *) pClient );
logClientClose ( pClient );
epicsMutexDestroy ( pClient->mutex );
epicsEventDestroy ( pClient->stateChangeNotify );
+ epicsEventDestroy ( pClient->shutdownNotify );
free ( pClient );
@@ -176,57 +173,23 @@ static void sendMessageChunk(logClient * pClient, const char * message) {
unsigned msgBufBytesLeft =
sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
- if ( strSize > msgBufBytesLeft ) {
- int status;
- if ( ! pClient->connected ) {
- break;
- if ( msgBufBytesLeft > 0u ) {
- memcpy ( & pClient->msgBuf[pClient->nextMsgIndex],
- message, msgBufBytesLeft );
- pClient->nextMsgIndex += msgBufBytesLeft;
- strSize -= msgBufBytesLeft;
- message += msgBufBytesLeft;
- status = send ( pClient->sock, pClient->msgBuf,
- pClient->nextMsgIndex, 0 );
- if ( status > 0 ) {
- unsigned nSent = (unsigned) status;
- if ( nSent < pClient->nextMsgIndex ) {
- unsigned newNextMsgIndex = pClient->nextMsgIndex - nSent;
- memmove ( pClient->msgBuf, & pClient->msgBuf[nSent],
- newNextMsgIndex );
- pClient->nextMsgIndex = newNextMsgIndex;
- else {
- else {
- if ( ! pClient->shutdown ) {
- char sockErrBuf[64];
- if ( status ) {
- epicsSocketConvertErrnoToString ( sockErrBuf, sizeof ( sockErrBuf ) );
- else {
- strcpy ( sockErrBuf, "server initiated disconnect" );
- fprintf ( stderr, "log client: lost contact with log server at \"%s\" because \"%s\"\n",
- pClient->name, sockErrBuf );
- logClientClose ( pClient );
- break;
+ if ( msgBufBytesLeft < strSize && pClient->nextMsgIndex != 0u && pClient->connected)
+ /* buffer is full, thus flush it */
+ logClientFlush ( pClient );
+ msgBufBytesLeft = sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
- else {
- message, strSize );
- pClient->nextMsgIndex += strSize;
+ if ( msgBufBytesLeft == 0u ) {
+ fprintf ( stderr, "log client: messages to \"%s\" are lost\n",
+ pClient->name );
break;
+ if ( msgBufBytesLeft > strSize) msgBufBytesLeft = strSize;
+ memcpy ( & pClient->msgBuf[pClient->nextMsgIndex],
+ message, msgBufBytesLeft );
+ pClient->nextMsgIndex += msgBufBytesLeft;
+ strSize -= msgBufBytesLeft;
+ message += msgBufBytesLeft;
@@ -255,28 +218,38 @@ void epicsShareAPI logClientSend ( logClientId id, const char * message )
void epicsShareAPI logClientFlush ( logClientId id )
+ unsigned nSent = 0u;
logClient * pClient = ( logClient * ) id;
- if ( ! pClient ) {
+ if ( ! pClient || ! pClient->connected ) {
return;
- while ( pClient->nextMsgIndex && pClient->connected ) {
- int status = send ( pClient->sock, pClient->msgBuf,
+ while (1) {
+ struct timeval timeout = { 0, 0 };
+ fd_set set;
+ char buffer[256];
+ FD_ZERO ( &set );
+ FD_SET ( pClient->sock, &set );
+ if ( select ( pClient->sock + 1, &set, NULL, NULL, &timeout ) == 0)
+ break;
+ if ( recv ( pClient->sock, buffer, sizeof ( buffer ), 0 ) == 0 ) {
+ fprintf ( stderr, "log client: connection closed by server \"%s\"\n",
+ pClient->name );
+ logClientClose ( pClient );
+ break;
+ while ( nSent < pClient->nextMsgIndex && pClient->connected ) {
+ int status = send ( pClient->sock, pClient->msgBuf + nSent,
+ pClient->nextMsgIndex - nSent, 0 );
if ( status > 0 ) {
- else {
+ nSent += (unsigned) status;
else {
@@ -294,6 +267,11 @@ void epicsShareAPI logClientFlush ( logClientId id )
break;
+ pClient->nextMsgIndex -= nSent;
+ if ( nSent > 0 && pClient->nextMsgIndex > 0 ) {
+ memmove ( pClient->msgBuf, & pClient->msgBuf[nSent],
+ pClient->nextMsgIndex );
@@ -399,20 +377,6 @@ static void logClientConnect (logClient *pClient)
- * we don't need full-duplex (clients only write), so we shutdown
- * the read end of our socket
- status = shutdown (pClient->sock, SHUT_RD);
- if (status < 0) {
- sockErrBuf, sizeof ( sockErrBuf ) );
- fprintf (stderr, "%s:%d shutdown(%d,SHUT_RD) error was \"%s\"\n",
- __FILE__, __LINE__, pClient->sock, sockErrBuf);
- /* not fatal (although it shouldn't happen) */
* set how long we will wait for the TCP state machine
* to clean up when we issue a close(). This
* guarantees that messages are serialized when we
@@ -457,14 +421,10 @@ static void logClientRestart ( logClientId id )
- if ( isConn ) {
- logClientFlush ( pClient );
- else {
- logClientConnect ( pClient );
- epicsThreadSleep ( LOG_RESTART_DELAY );
+ if ( ! isConn ) logClientConnect ( pClient );
+ epicsEventWaitWithTimeout ( pClient->shutdownNotify, LOG_RESTART_DELAY);
@@ -480,9 +440,7 @@ static void logClientRestart ( logClientId id )
logClientId epicsShareAPI logClientCreate (
struct in_addr server_addr, unsigned short server_port)
- epicsTimeStamp begin, current;
logClient *pClient;
- double diff;
pClient = calloc (1, sizeof (*pClient));
if (pClient==NULL) {
@@ -507,14 +465,22 @@ logClientId epicsShareAPI logClientCreate (
pClient->shutdownConfirm = 0;
epicsAtExit (logClientDestroy, (void*) pClient);
pClient->stateChangeNotify = epicsEventCreate (epicsEventEmpty);
if ( ! pClient->stateChangeNotify ) {
free ( pClient );
return NULL;
+ pClient->shutdownNotify = epicsEventCreate (epicsEventEmpty);
+ if ( ! pClient->shutdownNotify ) {
+ epicsMutexDestroy ( pClient->mutex );
+ epicsEventDestroy ( pClient->stateChangeNotify );
+ free ( pClient );
+ return NULL;
pClient->restartThreadId = epicsThreadCreate (
"logRestart", epicsThreadPriorityLow,
epicsThreadGetStackSize(epicsThreadStackSmall),
@@ -522,35 +488,12 @@ logClientId epicsShareAPI logClientCreate (
if ( pClient->restartThreadId == NULL ) {
free (pClient);
fprintf(stderr, "log client: unable to start log client connection watch dog thread\n");
return NULL;
- * attempt to synchronize with circuit connect
- epicsTimeGetCurrent ( & begin );
- epicsMutexMustLock ( pClient->mutex );
- do {
- epicsMutexUnlock ( pClient->mutex );
- epicsEventWaitWithTimeout (
- pClient->stateChangeNotify,
- LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT / 10.0 );
- epicsTimeGetCurrent ( & current );
- diff = epicsTimeDiffInSeconds ( & current, & begin );
- while ( ! pClient->connected && diff < LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT );
- fprintf (stderr, "log client create: timed out synchronizing with circuit connect to \"%s\" after %.1f seconds\n",
- pClient->name, LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT );
- errlogAddListener ( logClientSendMessage, (void *) pClient );
return (void *) pClient;
- [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Andrew Johnson via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Martin Konrad via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Ralph Lange via Core-talk
- [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
[Bug 1841608] Re: logClient falsely sends error logs on all connections Dirk Zimoch via Core-talk
<2019>
2025
2026
Build failed: EPICS Base base-7.0-422 AppVeyor via Core-talk
<2019>
2025
2026
