2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 04 Sep 2019 17:47:39 -0000
I notice that the page you link states:
> DISCLAIMER: This is my interpretation of the RFCs (I have read all the TCP-related ones I could find), but I have not attempted to examine implementation source code or trace actual connections in order to verify it. I am satisfied that the logic is correct, though.
which makes me smile.
The situation you describe, with a "firewall" in between is actually fairly complicated.  And opaque in that the firewall might be acting in different ways depending on how stateful and helpful it is (eg. whether one or both sides get RST).
What I understand about BSD sockets and TCP is that:
1. If the peer maintains the connection, but doesn't call recv() (at all, or not fast enough) then send() will eventually fill the Tx socket buffer FIFO and block until it becomes not full (by peer ACK on recv() ).
2. calling send() on a socket which has been closed (peer calls close()) while the TX FIFO is empty results in an immediate EPIPE.
3. if a send() is in progress because the Tx FIFO is full (or probably when not empty), a peer close results in ECONNRESET.
4. if a the peer has shutdown(SHUT_RD), then send() will succeed until the Tx FIFO is full, then it will block as with #2.  When the peer does close(), the send will return with EPIPE.  (or probably ECONNRESET if some data was sent, but not ACK'd before the FIN).
5. if the peer simply stops responding, then send() will succeed until the Tx FIFO is full, then block waiting for an ACK which never comes.
So normal, or abnormal, termination of the TCP connection will break a send() immediately after RST or the FIN+ACK handshake completes.  peer shutdown(SHUT_RD) or interruption of the network path will not break or error send().
I've just verified 1,2,3,4 on Linux with short python scripts.  (I was surprised that #4 doesn't error)  #5 I know from past experience.
So I don't think that calling recv() serves the purpose you intend.  I think that SO_SNDTIMEO would be a better fit.
That said, the recv() might serve as one piece of a mechanism for a log server to detect condition #5 faster than SO_KEEPALIVE would (imo. SO_KEEPALIVE should also be set).  Some extra protocol would be needed to allow a log server to detect this protocol feature.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Next: CALLBACK clash Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 05 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
