2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 05 Sep 2019 06:49:37 -0000
4. Was the problem. send does not fail until some time later. But than messages are already lost.
So my fix is not to rely on send failing but on recv returning EOF.
SO_KEEPALIVE has a default timeout of 2 hours and you cannot change it per socket but only system wide. It is totally useless for solving the problems with lost messages. It is there to allow to clean up stale connections and not to run out of file descriptors in server programs that are constantly running. But that's about all. So it may help the log server but not the client.
The problem I solve here is that send succeeds until the FIFO is full, just as you pointed out in 4. and 5.
I cannot confirm 2 though. My tests with ncat as a server have shown that send does not detect immediately when the server has exited (and thus the kernel has closed the socket).
But leaving discussions about how TCP is supposed to work aside, my main argument for this change is: Now it works, before it didn't.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: CALLBACK clash Michael Davidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 05 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
