2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 16 Sep 2019 08:50:58 -0000
The send() trick with 0 bytes does not work on all systems. It seems to depend on the Linux kernel version as well.
I am testing now a different solution. On Linux the call ioctl(sock, TIOCOUTQ, &unsent) gives the number of unsent bytes in the TCP output queue. This allows to keep the unsent bytes in the buffer in case it turns out later that the connection is broken.
On macOS there seems to be a similar functionality with getsockopt(sock, SOL_SOCKET, SO_NWRITE, &unsent), but I cannot test because I have no mac.
Other Unix flavors may or may not have such a feature.
For vxWorks I could not find a way to get the number of unsent bytes, neither for version 5.5 nor for 6.7.
I don't know about RTEMS.
On Windows 10 the number of unsent bytes should be available with WSAIoctl(sock, SIO_TCP_INFO, ..._). I spent most of last week to find out why it is not working before finding out that the Win 10 version I got was too old. I am upgrading now. Older Windows versions seem to have no way to find out the number of unsent bytes.
So I can mitigate the problem of message loss for some clients but not for all. Depending on the OS.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Jenkins build is back to normal : EPICS-3.14 #428 Jenkins EPICS PSI via Core-talk
Next: Re: Epics configure Makefile generation Heinz Junkes via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 16 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
