2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 30 Aug 2019 07:27:28 -0000
The proposal to merge ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 has been updated.
Description changed to:
Bugfix: don't send errlog to all logClients, only to iocLog
Improvements to minimize message loss when server disconnects:
* detect lost connection to server early
* do not discard buffer at disconnect
* flush buffer directly after reconnect
Other improvements:
* avoid delays on ioc startup and shutdown
* avoid repeated memmove
Relates to bug report https://bugs.launchpad.net/epics-base/+bug/1841608 and Tech-Talk thread https://epics.anl.gov/tech-talk/2019/msg01329.php.
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Next: pvPutLog? Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 03 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
