2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 04 Sep 2019 08:08:10 -0000
Unfortunately send() does not return an error immediately. It simply puts the message into the TCP send queue, even when the peer has already shut down the socket. Only one or more messages later send() returns an error. But by then the messages are lost. The logClient has already "successfully" sent them ti the TCP stack but TCP failed to deliver them and there is no way to recover the messages now.
>From the send man page: "No indication of failure to deliver is implicit in a send()."
It only tells you that queuing the message was successful.
When the peer closes the socket, select() will show the socket readable and read() will return 0, but only after everything the peer may have actually send has been read (and discarded).
That is the only reliable way to detect a closed connection.
However this method only works if the receiving side had not been shut down.
I had to google a lot until I found this out. It seems many people get this wrong assuming send() should fail immediately. It doesn't.
I can't find the page that helped me in the end any more, but this one comes close:
https://www.softlab.ntua.gr/facilities/documentation/unix/unix-socket-faq/unix-socket-faq-2.html
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372043
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 mdavidsaver via Core-talk
Next: [Bug 1842661] [NEW] seq record doesn't process LNK0 in "Specified" mode Joao Paulo Martins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 04 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
