2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: How to resolve git merge conflict in submodules?
From: "Zimoch Dirk \(PSI\) via Core-talk" <[email protected]>
Date: Fri, 20 Sep 2019 08:07:00 +0000
Hi all,
I have a git problem (again) and google and stackoverflow did not really help.
A merge failed with this status:
# Changes to be committed:
#	modified:   ../configure/CONFIG_BASE_VERSION
#	modified:   ../documentation/RELEASE_NOTES.html
#	modified:   ../documentation/ReleaseChecklist.html
#	modified:   ca/configure/CONFIG_CA_VERSION
#	modified:   database/configure/CONFIG_DATABASE_VERSION
#	modified:   database/src/ioc/misc/dbCore.dbd
#	modified:   libcom/configure/CONFIG_LIBCOM_VERSION
#	modified:   libcom/src/log/iocLog.c
#	modified:   libcom/src/log/iocLogServer.c
#	modified:   libcom/src/log/logClient.c
#	modified:   libcom/src/log/logClient.h
#	modified:   libcom/src/osi/os/RTEMS/devLibVMEOSD.c
#	modified:   normativeTypes
#	modified:   pva2pva
#	modified:   pvaClient
# Unmerged paths:
#   (use "git add <file>..." to mark resolution)
#	both modified:      pvAccess
#	both modified:      pvData
#	both modified:      pvDatabase
# Changes not staged for commit:
#   (use "git add <file>..." to update what will be committed)
#   (use "git checkout -- <file>..." to discard changes in working directory)
#	modified:   normativeTypes (new commits)
#	modified:   pva2pva (new commits)
#	modified:   pvaClient (new commits)
What can I do about pvAccess, pvData, and pvDatabase? I cannot even find out what the conflict is.
Dirk
Re: How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed: epics-base base-7.0-301 AppVeyor via Core-talk
ANJ, 20 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
