2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 23 Sep 2019 22:09:45 -0000
Dirk, I hope you won't take this as a disincentive, but I think a better approach would be either to switch to an actually reliable logging protocol, log over TLS with the heartbeat extension, switch to simply UDP logging, and/or teach caPutLog to use the system logging (aka call 'syslog()' or open '/dev/log').
I happened upon https://rainer.gerhards.net/2008/04/on-unreliability-of-plain-tcp-syslog.html which does a good job of summarizing some of the thoughts I've been having about iocLog "protocol" and the seeming impossibility of making it truly reliable while maintaining compatibility.
I also wonder if it would be better to move iocLogClient out of Base and into the caPutLog module as an internal API?  caPutLog seems to be the only (public) user of this API, and I think that removing the separation would enable a more effective restructuring of the code.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: RE: EPICS 7 build failures on Appveyor/Windows Freddie Akeroyd - UKRI STFC via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 23 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
