2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected],mdavidsaver <[email protected]>
Date: Wed, 18 Sep 2019 07:13:23 -0000
Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0.
Commit message:
fix several problems in logClient that lead to lost messages when the server (or firewall in between)  disconnects
Requested reviews:
  mdavidsaver (mdavidsaver)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Bugfix: don't send errlog to all logClients, only to iocLog
Improvements to minimize message loss when server disconnects:
* detect lost connection to server early
* do not discard buffer at disconnect
* flush buffer directly after reconnect
Other improvements:
* avoid delays on ioc startup and shutdown
* avoid repeated memmove
Relates to bug report https://bugs.launchpad.net/epics-base/+bug/1841608 and Tech-Talk thread https://epics.anl.gov/tech-talk/2019/msg01329.php.
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
diff --git a/modules/database/src/ioc/misc/dbCore.dbd b/modules/database/src/ioc/misc/dbCore.dbd
index 51f9c96..adde24e 100644
--- a/modules/database/src/ioc/misc/dbCore.dbd
+++ b/modules/database/src/ioc/misc/dbCore.dbd
@@ -33,3 +33,6 @@ variable(callbackParallelThreadsDefault,int)
 # Real-time operation
 variable(dbThreadRealtimeLock,int)
+# show logClient network activity
+variable(logClientDebug,int)
diff --git a/modules/libcom/src/log/iocLog.c b/modules/libcom/src/log/iocLog.c
index e62da20..8cb1349 100644
--- a/modules/libcom/src/log/iocLog.c
+++ b/modules/libcom/src/log/iocLog.c
@@ -18,8 +18,10 @@
 #define epicsExportSharedSymbols
 #include "envDefs.h"
+#include "errlog.h"
 #include "logClient.h"
 #include "iocLog.h"
+#include "epicsExit.h"
 int iocLogDisable = 0;
@@ -75,6 +77,14 @@ void epicsShareAPI epicsShareAPI iocLogFlush (void)
+ * logClientDestroy()
+static void iocLogClientDestroy (logClientId id)
+    errlogRemoveListeners (logClientSendMessage, id);
  *  iocLogClientInit()
 static logClientId iocLogClientInit (void)
@@ -89,6 +99,10 @@ static logClientId iocLogClientInit (void)
         return NULL;
     id = logClientCreate (addr, port);
+    if (id != NULL) {
+        errlogAddListener (logClientSendMessage, id);
+        epicsAtExit (iocLogClientDestroy, id);
     return id;
diff --git a/modules/libcom/src/log/logClient.c b/modules/libcom/src/log/logClient.c
index 99ee671..7627034 100644
--- a/modules/libcom/src/log/logClient.c
+++ b/modules/libcom/src/log/logClient.c
@@ -21,11 +21,9 @@
 #include <string.h>
 #include <stdio.h>
-#define epicsExportSharedSymbols
 #include "dbDefs.h"
 #include "epicsEvent.h"
 #include "iocLog.h"
-#include "errlog.h"
 #include "epicsMutex.h"
 #include "epicsThread.h"
 #include "epicsTime.h"
@@ -33,9 +31,13 @@
 #include "epicsAssert.h"
 #include "epicsSignal.h"
+#include "epicsExport.h"
+int logClientDebug = 0;
+epicsExportAddress (int, logClientDebug);
 typedef struct {
     char                msgBuf[0x4000];
     struct sockaddr_in  addr;
@@ -44,8 +46,10 @@ typedef struct {
     SOCKET              sock;
     epicsThreadId       restartThreadId;
     epicsEventId        stateChangeNotify;
+    epicsEventId        shutdownNotify;
     unsigned            connectCount;
     unsigned            nextMsgIndex;
+    unsigned            backlog;
     unsigned            connected;
     unsigned            shutdown;
     unsigned            shutdownConfirm;
@@ -53,7 +57,6 @@ typedef struct {
 } logClient;
 static const double      LOG_RESTART_DELAY = 5.0; /* sec */
-static const double      LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT = 5.0; /* sec */
 static const double      LOG_SERVER_SHUTDOWN_TIMEOUT = 30.0; /* sec */
@@ -66,10 +69,10 @@ static char* logClientPrefix = NULL;
 static void logClientClose ( logClient *pClient )
-#   ifdef DEBUG
+    if (logClientDebug) {
         fprintf (stderr, "log client: lingering for connection close...");
         fflush (stderr);
-#   endif
      * mutex on
@@ -84,8 +87,6 @@ static void logClientClose ( logClient *pClient )
         pClient->sock = INVALID_SOCKET;
-    pClient->nextMsgIndex = 0u;
-    memset ( pClient->msgBuf, '\0', sizeof ( pClient->msgBuf ) );
     pClient->connected = 0u;
@@ -93,9 +94,8 @@ static void logClientClose ( logClient *pClient )
     epicsMutexUnlock (pClient->mutex);
-#   ifdef DEBUG
         fprintf (stderr, "done\n");
-#   endif
@@ -113,6 +113,7 @@ static void logClientDestroy (logClientId id)
     epicsMutexMustLock ( pClient->mutex );
     pClient->shutdown = 1u;
     epicsMutexUnlock ( pClient->mutex );
+    epicsEventSignal ( pClient->shutdownNotify );
     /* unblock log client thread blocking in send() or connect() */
     interruptInfo =
@@ -154,13 +155,11 @@ static void logClientDestroy (logClientId id)
         return;
-    errlogRemoveListeners ( logClientSendMessage, (void *) pClient );
     logClientClose ( pClient );
     epicsMutexDestroy ( pClient->mutex );
     epicsEventDestroy ( pClient->stateChangeNotify );
+    epicsEventDestroy ( pClient->shutdownNotify );
     free ( pClient );
@@ -176,60 +175,59 @@ static void sendMessageChunk(logClient * pClient, const char * message) {
         unsigned msgBufBytesLeft =
             sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
-        if ( strSize > msgBufBytesLeft ) {
-            int status;
-            if ( ! pClient->connected ) {
-                break;
-            if ( msgBufBytesLeft > 0u ) {
-                memcpy ( & pClient->msgBuf[pClient->nextMsgIndex],
-                    message, msgBufBytesLeft );
-                pClient->nextMsgIndex += msgBufBytesLeft;
-                strSize -= msgBufBytesLeft;
-                message += msgBufBytesLeft;
-            status = send ( pClient->sock, pClient->msgBuf,
-                pClient->nextMsgIndex, 0 );
-            if ( status > 0 ) {
-                unsigned nSent = (unsigned) status;
-                if ( nSent < pClient->nextMsgIndex ) {
-                    unsigned newNextMsgIndex = pClient->nextMsgIndex - nSent;
-                    memmove ( pClient->msgBuf, & pClient->msgBuf[nSent],
-                        newNextMsgIndex );
-                    pClient->nextMsgIndex = newNextMsgIndex;
-                else {
-            else {
-                if ( ! pClient->shutdown ) {
-                    char sockErrBuf[64];
-                    if ( status ) {
-                        epicsSocketConvertErrnoToString ( sockErrBuf, sizeof ( sockErrBuf ) );
-                    else {
-                        strcpy ( sockErrBuf, "server initiated disconnect" );
-                    fprintf ( stderr, "log client: lost contact with log server at \"%s\" because \"%s\"\n",
-                        pClient->name, sockErrBuf );
-                logClientClose ( pClient );
-                break;
+        if ( msgBufBytesLeft < strSize && pClient->nextMsgIndex != 0u && pClient->connected)
+            /* buffer is full, thus flush it */
+            logClientFlush ( pClient );
+            msgBufBytesLeft = sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
-        else {
-                message, strSize );
-            pClient->nextMsgIndex += strSize;
+        if ( msgBufBytesLeft == 0u ) {
+            fprintf ( stderr, "log client: messages to \"%s\" are lost\n",
+                pClient->name );
             break;
+        if ( msgBufBytesLeft > strSize) msgBufBytesLeft = strSize;
+        memcpy ( & pClient->msgBuf[pClient->nextMsgIndex],
+            message, msgBufBytesLeft );
+        pClient->nextMsgIndex += msgBufBytesLeft;
+        strSize -= msgBufBytesLeft;
+        message += msgBufBytesLeft;
+ * epicsSockCountUnsentBytes ()
+ * Should go to osd socket support
+#if defined (_WIN32) && WINVER >= _WIN32_WINNT_WIN10
+#include <mstcpip.h>
+#endif
+static int epicsSockCountUnsentBytes(SOCKET sock) {
+/* Windows 10 Version 1703 / Server 2016 */
+/* https://docs.microsoft.com/en-us/windows/win32/api/mstcpip/ns-mstcpip-tcp_info_v0 */
+    DWORD infoVersion = 0, bytesReturned;
+    TCP_INFO_v0 tcpInfo;
+    int status;
+    if ((status = WSAIoctl(sock, SIO_TCP_INFO, &infoVersion, sizeof(infoVersion),
+        &tcpInfo, sizeof(tcpInfo), &bytesReturned, NULL, NULL)) == 0)
+        return tcpInfo.BytesInFlight;
+#elif defined (SO_NWRITE)
+/* macOS / iOS */
+/* https://www.unix.com/man-page/osx/2/setsockopt/ */
+    int unsent;
+    if (getsockopt(sock, SOL_SOCKET, SO_NWRITE, &unsent) == 0)
+        return unsent;
+#elif defined (TIOCOUTQ)
+/* Linux */
+/* https://linux.die.net/man/7/tcp */
+    int unsent;
+    if (ioctl(sock, TIOCOUTQ, &unsent) == 0)
+        return unsent;
+#endif
+    return 0;
  * logClientSend ()
@@ -255,43 +253,42 @@ void epicsShareAPI logClientSend ( logClientId id, const char * message )
 void epicsShareAPI logClientFlush ( logClientId id )
+    unsigned nSent;
+    int status = 0;
     logClient * pClient = ( logClient * ) id;
-    if ( ! pClient ) {
+    if ( ! pClient || ! pClient->connected ) {
         return;
-    while ( pClient->nextMsgIndex && pClient->connected ) {
-        int status = send ( pClient->sock, pClient->msgBuf,
-            else {
+    nSent = pClient->backlog;
+    while ( nSent < pClient->nextMsgIndex && pClient->connected ) {
+        status = send ( pClient->sock, pClient->msgBuf + nSent,
+            pClient->nextMsgIndex - nSent, 0 );
+        if ( status < 0 ) break;
+        nSent += status;
+    if ( status < 0 ) {
+        if ( ! pClient->shutdown ) {
+            char sockErrBuf[128];
+            epicsSocketConvertErrnoToString ( sockErrBuf, sizeof ( sockErrBuf ) );
+            fprintf ( stderr, "log client: lost contact with log server at \"%s\" because \"%s\"\n",
+                pClient->name, sockErrBuf );
-        else {
-                if ( status ) {
-                else {
-            break;
+        pClient->backlog = 0;
+        logClientClose ( pClient );
+    else if ( nSent > 0 && pClient->nextMsgIndex > 0 ) {
+        pClient->backlog = epicsSockCountUnsentBytes ( pClient->sock );
+        nSent -= pClient->backlog;
+        if ( nSent > 0 ) {
+            memmove ( pClient->msgBuf, & pClient->msgBuf[nSent],
+                pClient->nextMsgIndex );
+            pClient->nextMsgIndex -= nSent;
@@ -302,10 +299,10 @@ void epicsShareAPI logClientFlush ( logClientId id )
 static void logClientMakeSock (logClient *pClient)
-#   ifdef DEBUG
         fprintf (stderr, "log client: creating socket...");
-#   endif
+        fflush (stderr);
     epicsMutexMustLock (pClient->mutex);
@@ -314,7 +311,7 @@ static void logClientMakeSock (logClient *pClient)
     pClient->sock = epicsSocketCreate ( AF_INET, SOCK_STREAM, 0 );
     if ( pClient->sock == INVALID_SOCKET ) {
         fprintf ( stderr, "log client: no socket error %s\n",
@@ -323,10 +320,8 @@ static void logClientMakeSock (logClient *pClient)
-#   ifdef DEBUG
-#   endif
@@ -366,7 +361,7 @@ static void logClientConnect (logClient *pClient)
             else {
                 if ( pClient->connFailStatus != errnoCpy && ! pClient->shutdown ) {
                     fprintf (stderr,
@@ -392,7 +387,7 @@ static void logClientConnect (logClient *pClient)
     optval = TRUE;
     status = setsockopt (pClient->sock, SOL_SOCKET, SO_KEEPALIVE, (char *)&optval, sizeof(optval));
     if (status<0) {
         fprintf (stderr, "log client: unable to enable keepalive option because \"%s\"\n", sockErrBuf);
@@ -404,11 +399,11 @@ static void logClientConnect (logClient *pClient)
     status = shutdown (pClient->sock, SHUT_RD);
     if (status < 0) {
-        fprintf (stderr, "%s:%d shutdown(%d,SHUT_RD) error was \"%s\"\n",
-            __FILE__, __LINE__, pClient->sock, sockErrBuf);
+        fprintf (stderr, "%s:%d shutdown(sock,SHUT_RD) error was \"%s\"\n",
+            __FILE__, __LINE__, sockErrBuf);
         /* not fatal (although it shouldn't happen) */
@@ -425,7 +420,7 @@ static void logClientConnect (logClient *pClient)
         lingerval.l_linger = 60*5;
         status = setsockopt (pClient->sock, SOL_SOCKET, SO_LINGER, (char *) &lingerval, sizeof(lingerval));
         if (status<0) {
             fprintf (stderr, "log client: unable to set linger options because \"%s\"\n", sockErrBuf);
@@ -457,14 +452,10 @@ static void logClientRestart ( logClientId id )
-        if ( isConn ) {
-            logClientFlush ( pClient );
-        else {
-            logClientConnect ( pClient );
-        epicsThreadSleep ( LOG_RESTART_DELAY );
+        if ( ! isConn ) logClientConnect ( pClient );
+        epicsEventWaitWithTimeout ( pClient->shutdownNotify, LOG_RESTART_DELAY);
@@ -480,9 +471,7 @@ static void logClientRestart ( logClientId id )
 logClientId epicsShareAPI logClientCreate (
     struct in_addr server_addr, unsigned short server_port)
-    epicsTimeStamp begin, current;
     logClient *pClient;
-    double diff;
     pClient = calloc (1, sizeof (*pClient));
     if (pClient==NULL) {
@@ -507,14 +496,22 @@ logClientId epicsShareAPI logClientCreate (
     pClient->shutdownConfirm = 0;
     epicsAtExit (logClientDestroy, (void*) pClient);
     pClient->stateChangeNotify = epicsEventCreate (epicsEventEmpty);
     if ( ! pClient->stateChangeNotify ) {
         free ( pClient );
         return NULL;
+    pClient->shutdownNotify = epicsEventCreate (epicsEventEmpty);
+    if ( ! pClient->shutdownNotify ) {
+        epicsMutexDestroy ( pClient->mutex );
+        epicsEventDestroy ( pClient->stateChangeNotify );
+        free ( pClient );
+        return NULL;
     pClient->restartThreadId = epicsThreadCreate (
         "logRestart", epicsThreadPriorityLow,
         epicsThreadGetStackSize(epicsThreadStackSmall),
@@ -522,35 +519,12 @@ logClientId epicsShareAPI logClientCreate (
     if ( pClient->restartThreadId == NULL ) {
         free (pClient);
         fprintf(stderr, "log client: unable to start log client connection watch dog thread\n");
         return NULL;
-     * attempt to synchronize with circuit connect
-    epicsTimeGetCurrent ( & begin );
-    epicsMutexMustLock ( pClient->mutex );
-    do {
-        epicsMutexUnlock ( pClient->mutex );
-        epicsEventWaitWithTimeout (
-            pClient->stateChangeNotify,
-            LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT / 10.0 );
-        epicsTimeGetCurrent ( & current );
-        diff = epicsTimeDiffInSeconds ( & current, & begin );
-    while ( ! pClient->connected && diff < LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT );
-        fprintf (stderr, "log client create: timed out synchronizing with circuit connect to \"%s\" after %.1f seconds\n",
-            pClient->name, LOG_SERVER_CREATE_CONNECT_SYNC_TIMEOUT );
-    errlogAddListener ( logClientSendMessage, (void *) pClient );
     return (void *) pClient;
@@ -568,14 +542,21 @@ void epicsShareAPI logClientShow (logClientId id, unsigned level)
         printf ("log client: disconnected from log server at \"%s\"\n", pClient->name);
-    if (level>1) {
-        printf ("log client: sock=%s, connect cycles = %u\n",
+    if (logClientPrefix) {
+        printf ("log client: prefix is \"%s\"\n", logClientPrefix);
+    if (level>0) {
+        printf ("log client: sock %s, connect cycles = %u\n",
             pClient->sock==INVALID_SOCKET?"INVALID":"OK",
             pClient->connectCount);
-    if (logClientPrefix) {
-        printf ("log client: prefix is \"%s\"\n", logClientPrefix);
+    if (level>1) {
+        printf ("log client: %u bytes in buffer\n", pClient->nextMsgIndex);
+        if (pClient->nextMsgIndex)
+            printf("-------------------------\n"
+                "%.*s-------------------------\n",
+                (int)(pClient->nextMsgIndex), pClient->msgBuf);
Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Andrew Johnson via Core-talk
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 noreply--- via Core-talk
Prev: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixes into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0 noreply--- via Core-talk
ANJ, 28 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
