2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 25 Oct 2019 01:48:03 -0000
Review: Needs Fixing
I did a test merge.  Some CI failures resulted with cross-mingw and some older MSVC.  Looks like some of the defines and structs related to TCP_INFO aren't available.
https://ci.appveyor.com/project/mdavidsaver/epics-base/builds/28358563
https://travis-ci.org/mdavidsaver/epics-base/builds/602443942
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-7.0-346 AppVeyor via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 24 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
