2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 18 Sep 2019 07:48:00 -0000
The "resubmit proposal" link seems to do the job. It allows to switch branches. No force push needed. Diffs look fine and the conversation gets transferred.
Martin, the smaller steps are the individual commits. Each should be one (and in most cases small and understandable) change. Each commit I did results in working code. So if there is a problem with one particular step, it can be reverted.
I am not yet quite satisfied with the behavior, so some more changes may come. But please have a look already.
My test:
Start iocLogServer
Start softIoc and do ioclogInit
errlog msg1
Stop iocLogServer and restart it
errlog msg2
wait at least 10 seconds
errlog msg3
All 3 error messages should be logged.
On Linux (all version?) connection loss is detected latest 5 seconds after msg2.
On recent Win 10 connection loss is detected at only at msg3 because send(sock,NULL,0) has no effect,
 but no message is lost.
On vxWorks 5.5 and older Windows versions (< Win 10 version 1703) msg2 is lost because they have no o way to detect when a message is actually sent on the network.
Can someone test with Mac and RTEMS?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build failed: epics-base base-7.0-299 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 18 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
