2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 18 Sep 2019 14:35:54 -0000
I did that briefly. The client (ioc) happily sends to the server and on the server the TCP input queue fills up. If the server then dies the messages are lost.
I have not tried it until the queues filled up. The the logClient may block while holding the mutex which may make errlog (or whatever client) block. I will test that.
I suggest to remove the code that attempts to send from sendMessageChunk() and accept (and report) that messages are lost.
Can you please also review the usage of the mutex in the original code. I have the impression it does not really make sense.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
