2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 23 Sep 2019 22:24:04 -0000
I think the 'send(NULL)' pattern is a race condition as it depends on a TCP reset message having arrived prior to the second send(NULL) call.  With real network latency I don't think it will work as intended to quickly and reliably detect when the preceding send() elicits a RST.
I'm not going to insist on a change here because I don't think it will break anything.  The RST just won't be handled (via. EPIPE) unless the next time the log queue is flushed, and send() is called again.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
Next: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 23 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
