2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 02 Oct 2019 20:30:28 -0000
Results of discussion at core dev. meeting
Add '#ifdef EPICS_PRIVATE_API' around declaration of epicsSocketCountUnsentBytes() in osiSock.h.
Also, can you confirm that you've tested this (final) version on a target where epicsSocketCountUnsentBytes()==-1 ?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/372925
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Jenkins build is still unstable: epics-7.0 » linux64 #154 APS Jenkins via Core-talk
Next: [Bug 1845854] Re: EPICS Math tests failing on Windows with MSVC mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:iocLogClientFixesTry2 into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 03 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
