2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/database:epicsCallback into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Thu, 26 Sep 2019 20:37:34 -0000
> I moved the #include "osiSock.h" lines that Michael had added to a couple of the pva2pva sources to resolve the Windows build problems
I was reminded today of why I had put osiSock.h where it was.  If I don't, then my cross-mingw builds fail after warning "Please include winsock2.h before windows.h".  Does this mean that osiSock.h should be including windows.h as well?
In file included from /home/mdavidsaver/work/epics/base-git/include/os/WIN32/osdSock.h:23,
                 from /home/mdavidsaver/work/epics/base-git/include/osiSock.h:19,
                 from ../pdbsingle.cpp:11:
/usr/share/mingw-w64/include/winsock2.h:15:2: warning: #warning Please include winsock2.h before windows.h [-Wcpp]
/usr/share/mingw-w64/include/winsock2.h:541:24: error: expected ‘)’ before ‘*’ token
   typedef int (CALLBACK *LPCONDITIONPROC)(LPWSABUF lpCallerId,LPWSABUF lpCallerData,LPQOS lpSQOS,LPQOS lpGQOS,LPWSABUF lpCalleeId,LPWSABUF lpCalleeData,GROUP *g,DWORD_PTR dwCallbackData);
/usr/share/mingw-w64/include/winsock2.h:542:25: error: expected ‘)’ before ‘*’ token
   typedef void (CALLBACK *LPWSAOVERLAPPED_COMPLETION_ROUTINE)(DWORD dwError,DWORD cbTransferred,LPWSAOVERLAPPED lpOverlapped,DWORD dwFlags);
/usr/share/mingw-w64/include/winsock2.h:567:2: error: ‘LPWSAOVERLAPPED_COMPLETION_ROUTINE’ does not name a type; did you mean ‘LPOVERLAPPED_COMPLETION_ROUTINE’?
  LPWSAOVERLAPPED_COMPLETION_ROUTINE lpfnCompletionProc;
... omitting many similar errors
https://code.launchpad.net/~epics-core/epics-base/+git/database/+merge/372385
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/database:epicsCallback into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~bhill/epics-base:shared-rpath-independent-of-static-build into epics-base:7.0 rivers via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/database:epicsCallback into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/database:epicsCallback into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 26 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
