2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: SIGTRAP in EPICS 7.0.3
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Wed, 9 Oct 2019 09:07:17 -0700
On 10/9/19 7:21 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> On Wed, 2019-10-09 at 12:30 +0000, Zimoch Dirk (PSI) via Core-talk wrote:
>> Hi everyone,
>> On one of my embedded Linux architectures I get a SIGTRAP when executing iocInit in softIocPVA.
Is this process attached to a debugger?  I've only encountered SIGTRAP in the mechanics of breakpoints.
>> This is the stack trace:
>> #0  0x0fdadd3c in typeinfo for epics::pvAccess::ChannelArray () from /usr/local/epics/base-7.0.3/lib/eldk42-
> Seems to be a bug in the optimizer of gcc 4.2.2. The problem disappears with -fno-inline-functions.
This may be a premature conclusion.  It's also possible that the code involved has a bug.
This code seems to work with gcc 4.3.2 (RTEMS 4.9.6).
Can you try running with valgrind to get some more insight?
Also, can you run the unittests and report any failures?
And thank you for testing the 7.0.3 release ;)
SIGTRAP in EPICS 7.0.3 Zimoch Dirk (PSI) via Core-talk
Re: SIGTRAP in EPICS 7.0.3 Zimoch Dirk (PSI) via Core-talk
Prev: Re: SIGTRAP in EPICS 7.0.3 Zimoch Dirk (PSI) via Core-talk
Next: Jenkins build became unstable: epics-pva2pva-linux32 #150 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 09 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
