2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #223
From: Jenkins EPICS PSI via Core-talk <[email protected]>
To: <[email protected]>, <[email protected]>
Date: Sun, 20 Oct 2019 20:32:25 +0200
See <http://gfa-sls2-test:8080/job/EPICS-7/223/display/redirect?page=changes>
Changes:
[mdavidsaver] LINKER_USE_RPATH=ORIGIN
[mdavidsaver] epicsGetExecDir() paths relative to executable
[mdavidsaver] epicsGetExecName WIN32, Darwin, solaris, freebsd
[mdavidsaver] travis-ci test rpath $ORIGIN
[mdavidsaver] older binutils compat
[mdavidsaver] monotonic adapt to regular time APIs
[mdavidsaver] dbScan periodic scan use monotonic time
[mdavidsaver] replace most internal getCurrent() -> getMonotonic()
[mdavidsaver] iocsh catch exceptions
[mdavidsaver] iocsh control error behavior
[mdavidsaver] iocsh allow setting of error code
[mdavidsaver] use iocshSetError()
[mdavidsaver] Fixed logic errors and added some prompts.
[mdavidsaver] iocsh further on error
[mdavidsaver] iocsh trap arg. parsing errors
[mdavidsaver] rpath $ORIGIN doc
[mdavidsaver] redo softIoc to be more c++y
[mdavidsaver] makeRPath allow multiple root directories
[anj] VxWorks: Measure CPU time-base frequency if necessary
[mdavidsaver] iocsh handle redirect and similar early errors
[mdavidsaver] iocsh more error handling
[mdavidsaver] iocshCmd() imply "on error break"
[mdavidsaver] iocshTest start
[mdavidsaver] deprecate iocshFindCommand()
[mdavidsaver] doc
[bhill] Shared lib rpath should not depend on whether or not static libs are
[bhill] Also apply rpath change to PRODDIR_RPATH_LDFLAGS
[bhill] Fix comment as well
[bhill] Another comment fix
[freddie.akeroyd] Enable VS 2019 and debug builds on Appveyor
[freddie.akeroyd] Exclude VS2012 from -FS option
[freddie.akeroyd] Formatting
[freddie.akeroyd] Use MY_OS to avoid conflict with existing OS variable
[freddie.akeroyd] Set PERLVER outside if clause
[mdavidsaver] workaround apparent MSVC mis-optimization
[mdavidsaver] asLib: osiSockAttach() for asCheckClientIP
[mdavidsaver] avoid prove executable
[mdavidsaver] appveyor test-results
[mdavidsaver] appveyor always push artifacts
[mdavidsaver] update release notes
[mdavidsaver] RSRV: fix large buffer resize
[mdavidsaver] msvc unittests disable dialog on error or assert() failure
[mdavidsaver] WIN32: Add stack trace printing on assert/error
[mdavidsaver] WIN32: Add symbol lookup
[mdavidsaver] appveyor reorder and prune
[mdavidsaver] libcom: win32 poison TLS value
[mdavidsaver] update PVA modules
[...truncated 1.37 MB...]
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//timer/timerQueuePassive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl_alloc.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl_buf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl_encode.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl_gen.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl_lex.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//yajl/yajl_parser.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/osiNTPTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/os/vxWorks/atReboot.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/os/vxWorks/epicsDynLink.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/os/vxWorks/veclist.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/os/vxWorks/logMsgToErrlog.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/os/vxWorks/strtoll.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h    -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/vxWorks -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ..//osi/os/vxWorks/strtoull.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/arppc -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o atReboot.o epicsDynLink.o veclist.o logMsgToErrlog.o strtoll.o strtoull.o
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ranlibppc libCom.a
Installing library ../../../../lib/V63-ppc603/libCom.a
Installing created executable ../../../../bin/V63-ppc603/vxComLibrary.o
mkdir ../../../../bin/V63-ppc603
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
make -C O.moxa42-armv6l -f ../Makefile TOP=../../../.. \
    T_A=moxa42-armv6l install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.moxa42-armv6l'>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_parser.d  ..//yajl/yajl_parser.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_lex.d  ..//yajl/yajl_lex.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_gen.d  ..//yajl/yajl_gen.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_encode.d  ..//yajl/yajl_encode.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_buf.d  ..//yajl/yajl_buf.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_alloc.d  ..//yajl/yajl_alloc.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl.d  ..//yajl/yajl.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueuePassive.d  ..//timer/timerQueuePassive.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueueActiveMgr.d  ..//timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueueActive.d  ..//timer/timerQueueActive.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueue.d  ..//timer/timerQueue.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timer.d  ..//timer/timer.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimer.d  ..//timer/epicsTimer.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF taskwd.d  ..//taskwd/taskwd.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsRingBytes.d  ..//ring/epicsRingBytes.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsRingPointer.d  ..//ring/epicsRingPointer.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF threadPool.d  ..//pool/threadPool.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF poolJob.d  ..//pool/poolJob.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdFindAddr.d  ..//osi/os/Linux/osdFindAddr.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdBackTrace.d  ..//osi/os/Linux/osdBackTrace.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStackTrace.d  ..//osi/epicsStackTrace.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF devLibVMEOSD.d  ..//osi/os/default/devLibVMEOSD.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF devLibVME.d  ..//osi/devLibVME.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdgetexec.d  ..//osi/os/Linux/osdgetexec.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMessageQueue.d  ..//osi/os/default/osdMessageQueue.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdNetIntf.d  ..//osi/os/default/osdNetIntf.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdProcess.d  ..//osi/os/posix/osdProcess.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMonotonic.d  ..//osi/os/posix/osdMonotonic.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdTime.d  ..//osi/os/posix/osdTime.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdEvent.d  ..//osi/os/posix/osdEvent.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSpin.d  ..//osi/os/posix/osdSpin.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMutex.d  ..//osi/os/posix/osdMutex.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThreadHooks.d  ..//osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThreadExtra.d  ..//osi/os/Linux/osdThreadExtra.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThread.d  ..//osi/os/posix/osdThread.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdStdio.d  ..//osi/os/posix/osdStdio.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdio.d  ..//osi/epicsStdio.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTempFile.d  ..//osi/os/posix/epicsTempFile.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE_NCURSES    -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsReadline.d  ..//osi/epicsReadline.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdEnv.d  ..//osi/os/default/osdEnv.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSignal.d  ..//osi/os/posix/osdSignal.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdPoolStatus.d  ..//osi/os/default/osdPoolStatus.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdInterrupt.d  ..//osi/os/default/osdInterrupt.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdFindSymbol.d  ..//osi/os/posix/osdFindSymbol.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdAssert.d  ..//osi/os/default/osdAssert.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSocketConvertErrnoToString.d  ..//osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF systemCallIntMech.d  ..//osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiSock.d  ..//osi/osiSock.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSockAddrReuse.d  ..//osi/os/posix/osdSockAddrReuse.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSock.d  ..//osi/os/posix/osdSock.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiClockTime.d  ..//osi/osiClockTime.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsGeneralTime.d  ..//osi/epicsGeneralTime.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicOSD.d  ..//osi/os/posix/epicsAtomicOSD.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMath.d  ..//osi/epicsMath.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMessageQueue.d  ..//osi/epicsMessageQueue.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTime.d  ..//osi/epicsTime.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEvent.d  ..//osi/epicsEvent.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMutex.d  ..//osi/epicsMutex.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThread.d  ..//osi/epicsThread.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsUnitTest.d  ..//misc/epicsUnitTest.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ipAddrToAsciiAsynchronous.d  ..//misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF truncateFile.d  ..//misc/truncateFile.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsString.d  ..//misc/epicsString.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdlib.d  ..//misc/epicsStdlib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsExit.d  ..//misc/epicsExit.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsConvert.d  ..//misc/epicsConvert.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cantProceed.d  ..//misc/cantProceed.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF adjustment.d  ..//misc/adjustment.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF aToIPAddr.d  ..//misc/aToIPAddr.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF alarmString.d  ..//misc/alarmString.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macUtil.d  ..//macLib/macUtil.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macEnv.d  ..//macLib/macEnv.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macCore.d  ..//macLib/macCore.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF logClient.d  ..//log/logClient.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocLog.d  ..//log/iocLog.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF libComRegister.d  ..//iocsh/libComRegister.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF registry.d  ..//iocsh/registry.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF initHooks.d  ..//iocsh/initHooks.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocsh.d  ..//iocsh/iocsh.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF gpHashLib.d  ..//gpHash/gpHashLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF freeListLib.d  ..//freeList/freeListLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF fdManager.d  ..//fdmgr/fdManager.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF fdmgr.d  ..//fdmgr/fdmgr.cpp
perl -CSD ..//error/makeStatTbl.pl  ..//osi/devLib.h ..//osi/epicsTime.h ..//as/asLib.h ..//misc/epicsStdlib.h ..//pool/epicsThreadPool.h ..//error/errMdef.h
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errSymTbl.d  errSymTbl.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errSymLib.d  ..//error/errSymLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errlog.d  ..//error/errlog.c
perl -CSD ../../../../bin/RHEL7-x86_64/bldEnvData.pl  -t moxa42-armv6l \
	-c gcc -s Linux ../../../../configure
Generating envData.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF envData.d  envData.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF envSubr.d  ..//env/envSubr.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ellSort.d  ..//ellLib/ellSort.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ellLib.d  ..//ellLib/ellLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF dbmf.d  ..//dbmf/dbmf.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSingletonMutex.d  ..//cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF resourceLib.d  ..//cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFast.d  ..//cvtFast/cvtFast.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF calcPerform.d  ..//calc/calcPerform.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF postfix.d  ..//calc/postfix.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF bucketLib.d  ..//bucketLib/bucketLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF asTrapWrite.d  ..//as/asTrapWrite.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/e_flex> -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ..//as/asLib_lex.l
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -basLib  ..//as/asLib.y
mv asLib.tab.c asLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF asLib.d  asLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF warshall.d  ..//yacc/warshall.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF verbose.d  ..//yacc/verbose.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF symtab.d  ..//yacc/symtab.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF skeleton.d  ..//yacc/skeleton.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF reader.d  ..//yacc/reader.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF output.d  ..//yacc/output.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF mkpar.d  ..//yacc/mkpar.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF antelope.d  ..//yacc/antelope.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF lr0.d  ..//yacc/lr0.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF lalr.d  ..//yacc/lalr.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF error.d  ..//yacc/error.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF closure.d  ..//yacc/closure.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocLogServer.d  ..//log/iocLogServer.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -bparse -l -d ..//flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static     -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF parse.d  parse.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF tblcmp.d  ..//flex/tblcmp.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF sym.d  ..//flex/sym.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF nfa.d  ..//flex/nfa.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF misc.d  ..//flex/misc.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF gen.d  ..//flex/gen.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ecs.d  ..//flex/ecs.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF dfa.d  ..//flex/dfa.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables       -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ccl.d  ..//flex/ccl.c
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.moxa42-armv6l'>
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.moxa42-armv6l'>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c asLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//as/asTrapWrite.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//bucketLib/bucketLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//calc/postfix.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//calc/calcPerform.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//cvtFast/cvtFast.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//dbmf/dbmf.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//ellLib/ellLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//ellLib/ellSort.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//env/envSubr.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c envData.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//error/errlog.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//error/errSymLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c errSymTbl.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//fdmgr/fdmgr.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//fdmgr/fdManager.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//freeList/freeListLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//gpHash/gpHashLib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//iocsh/iocsh.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//iocsh/initHooks.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//iocsh/registry.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//iocsh/libComRegister.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//log/iocLog.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//log/logClient.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//macLib/macCore.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//macLib/macEnv.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//macLib/macUtil.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/alarmString.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/aToIPAddr.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/adjustment.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/cantProceed.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/epicsConvert.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/epicsExit.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/epicsStdlib.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/epicsString.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/truncateFile.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//misc/epicsUnitTest.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsThread.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsMutex.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsEvent.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsTime.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsMessageQueue.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsMath.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/epicsAtomicOSD.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsGeneralTime.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/osiClockTime.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdSock.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdSockAddrReuse.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/osiSock.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdAssert.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdFindSymbol.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdInterrupt.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdPoolStatus.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdSignal.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdEnv.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE_NCURSES    -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsReadline.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/epicsTempFile.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/epicsStdio.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdStdio.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdThread.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/Linux/osdThreadExtra.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdMutex.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdSpin.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdEvent.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdTime.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdMonotonic.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/posix/osdProcess.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdNetIntf.c
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables -Wno-psabi      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/default/osdMessageQueue.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3   -Wall       -funwind-tables      -fPIC -I. -I../O.Common -I. -I..//osi/compiler/gcc -I..//osi/compiler/default -I. -I..//osi/os/Linux -I..//osi/os/posix -I..//osi/os/default -I.. -I..//as -I..//bucketLib -I..//calc -I..//cvtFast -I..//cppStd -I..//cxxTemplates -I..//dbmf -I..//ellLib -I..//env -I..//error -I..//fdmgr -I..//flex -I..//freeList -I..//gpHash -I..//iocsh -I..//log -I..//macLib -I..//misc -I..//osi -I..//pool -I..//ring -I..//taskwd -I..//timer -I..//yacc -I..//yacc -I..//yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ..//osi/os/Linux/osdgetexec.c
..//osi/os/Linux/osdgetexec.c: In function ‘epicsGetExecName’:
..//osi/os/Linux/osdgetexec.c:12: error: ‘PATH_MAX’ undeclared (first use in this function)
..//osi/os/Linux/osdgetexec.c:12: error: (Each undeclared identifier is reported only once
..//osi/os/Linux/osdgetexec.c:12: error: for each function it appears in.)
make[4]: *** [osdgetexec.o] Error 1
make[3]: *** [install.moxa42-armv6l] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src'>
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom'>
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-7 #224 Jenkins EPICS PSI via Core-talk
Prev: Build failed: EPICS Base base-7.0-463 AppVeyor via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-linux32 #413 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Jenkins build is back to normal : EPICS-7 #224 Jenkins EPICS PSI via Core-talk
ANJ, 21 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
