2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-linux32 #413
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Sun, 20 Oct 2019 17:09:31 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/413/display/redirect?page=changes>
Changes:
[Andrew Johnson] rename .dbd to .dpd.pod for mbbiDirect
[Andrew Johnson] Add converted mbbiDirect POD
[Andrew Johnson] rename .dbd to .dpd.pod for mbbo
[Andrew Johnson] Add converted mbbo POD
[Andrew Johnson] Perl-generated HTML is UTF-8; mark it so
[Andrew Johnson] Cleanup of POD documentation, unifying some things
[Andrew Johnson] Release notes describing Record POD changes
[Andrew Johnson] Word-wrap release notes to 80 columns
[...truncated 495.01 KB...]
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registryIocRegister.d  ../../../src/ioc/registry/registryIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registryCommon.d  ../../../src/ioc/registry/registryCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registryFunction.d  ../../../src/ioc/registry/registryFunction.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registryDriverSupport.d  ../../../src/ioc/registry/registryDriverSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registryDeviceSupport.d  ../../../src/ioc/registry/registryDeviceSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registryRecordType.d  ../../../src/ioc/registry/registryRecordType.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF iocshRegisterCommon.d  ../../../src/ioc/misc/iocshRegisterCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dlload.d  ../../../src/ioc/misc/dlload.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF miscIocRegister.d  ../../../src/ioc/misc/miscIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF iocInit.d  ../../../src/ioc/misc/iocInit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsRelease.d  ../../../src/ioc/misc/epicsRelease.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbtoolsIocRegister.d  ../../../src/ioc/dbtemplate/dbtoolsIocRegister.c
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/e_flex> -S../../../include/flex.skel.static -8 -I -odbLoadTemplate_lex.c ../../../src/ioc/dbtemplate/dbLoadTemplate_lex.l
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/antelope> -bdbLoadTemplate  ../../../src/ioc/dbtemplate/dbLoadTemplate.y
mv dbLoadTemplate.tab.c dbLoadTemplate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbLoadTemplate.d  dbLoadTemplate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbStaticIocRegister.d  ../../../src/ioc/dbStatic/dbStaticIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbStaticRun.d  ../../../src/ioc/dbStatic/dbStaticRun.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbPvdLib.d  ../../../src/ioc/dbStatic/dbPvdLib.c
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/e_flex> -S../../../include/flex.skel.static -8 -I -odbLex.c ../../../src/ioc/dbStatic/dbLex.l
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/antelope> -bdbYacc  ../../../src/ioc/dbStatic/dbYacc.y
mv dbYacc.tab.c dbYacc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbYacc.d  dbYacc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbStaticLib.d  ../../../src/ioc/dbStatic/dbStaticLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbServer.d  ../../../src/ioc/db/dbServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbUnitTest.d  ../../../src/ioc/db/dbUnitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbState.d  ../../../src/ioc/db/dbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF chfPlugin.d  ../../../src/ioc/db/chfPlugin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbIocRegister.d  ../../../src/ioc/db/dbIocRegister.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF templateInstances.d  ../../../src/ioc/db/templateInstances.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbContextReadNotifyCache.d  ../../../src/ioc/db/dbContextReadNotifyCache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbPutNotifyBlocker.d  ../../../src/ioc/db/dbPutNotifyBlocker.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbSubscriptionIO.d  ../../../src/ioc/db/dbSubscriptionIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbChannelIO.d  ../../../src/ioc/db/dbChannelIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbContext.d  ../../../src/ioc/db/dbContext.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF cvtBpt.d  ../../../src/ioc/db/cvtBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF initHooks.d  ../../../src/ioc/db/initHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbCaTest.d  ../../../src/ioc/db/dbCaTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbCa.d  ../../../src/ioc/db/dbCa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF callback.d  ../../../src/ioc/db/callback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF recGbl.d  ../../../src/ioc/db/recGbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF db_test.d  ../../../src/ioc/db/db_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF db_access.d  ../../../src/ioc/db/db_access.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbTest.d  ../../../src/ioc/db/dbTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbEvent.d  ../../../src/ioc/db/dbEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbScan.d  ../../../src/ioc/db/dbScan.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbNotify.d  ../../../src/ioc/db/dbNotify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbLink.d  ../../../src/ioc/db/dbLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbExtractArray.d  ../../../src/ioc/db/dbExtractArray.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbFastLinkConv.d  ../../../src/ioc/db/dbFastLinkConv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbConvert.d  ../../../src/ioc/db/dbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbChannel.d  ../../../src/ioc/db/dbChannel.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbBkpt.d  ../../../src/ioc/db/dbBkpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbAccess.d  ../../../src/ioc/db/dbAccess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbLock.d  ../../../src/ioc/db/dbLock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF asIocRegister.d  ../../../src/ioc/as/asIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF asCa.d  ../../../src/ioc/as/asCa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF asDbLib.d  ../../../src/ioc/as/asDbLib.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF msi.d  ../../../src/ioc/dbtemplate/msi.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF makeBpt.d  ../../../src/ioc/bpt/makeBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF ascheck.d  ../../../src/ioc/as/ascheck.c
Installing generic include file ../../../include/asDbLib.h
Installing generic include file ../../../include/asCa.h
Installing generic include file ../../../include/asIocRegister.h
Installing generic include file ../../../include/cvtTable.h
Installing generic include file ../../../include/callback.h
Installing generic include file ../../../include/dbAccess.h
Installing generic include file ../../../include/dbAccessDefs.h
Installing generic include file ../../../include/dbCa.h
Installing generic include file ../../../include/dbAddr.h
Installing generic include file ../../../include/dbBkpt.h
Installing generic include file ../../../include/dbChannel.h
Installing generic include file ../../../include/dbConvert.h
Installing generic include file ../../../include/dbConvertFast.h
Installing generic include file ../../../include/dbExtractArray.h
Installing generic include file ../../../include/dbEvent.h
Installing generic include file ../../../include/dbLink.h
Installing generic include file ../../../include/dbLock.h
Installing generic include file ../../../include/dbNotify.h
Installing generic include file ../../../include/dbScan.h
Installing generic include file ../../../include/dbServer.h
Installing generic include file ../../../include/dbTest.h
Installing generic include file ../../../include/dbCaTest.h
Installing generic include file ../../../include/db_test.h
Installing generic include file ../../../include/db_field_log.h
Installing generic include file ../../../include/initHooks.h
Installing generic include file ../../../include/recGbl.h
Installing generic include file ../../../include/dbIocRegister.h
Installing generic include file ../../../include/chfPlugin.h
Installing generic include file ../../../include/dbState.h
Installing generic include file ../../../include/db_access_routines.h
Installing generic include file ../../../include/db_convert.h
Installing generic include file ../../../include/dbUnitTest.h
Installing generic include file ../../../include/dbBase.h
Installing generic include file ../../../include/dbFldTypes.h
Installing generic include file ../../../include/dbStaticLib.h
Installing generic include file ../../../include/dbStaticPvt.h
Installing generic include file ../../../include/link.h
Installing generic include file ../../../include/special.h
Installing generic include file ../../../include/guigroup.h
Installing generic include file ../../../include/devSup.h
Installing generic include file ../../../include/drvSup.h
Installing generic include file ../../../include/recSup.h
Installing generic include file ../../../include/dbStaticIocRegister.h
Installing generic include file ../../../include/dbLoadTemplate.h
Installing generic include file ../../../include/dbtoolsIocRegister.h
Installing generic include file ../../../include/epicsRelease.h
Installing generic include file ../../../include/iocInit.h
Installing generic include file ../../../include/miscIocRegister.h
Installing generic include file ../../../include/iocshRegisterCommon.h
Installing generic include file ../../../include/registryRecordType.h
Installing generic include file ../../../include/registryDeviceSupport.h
Installing generic include file ../../../include/registryDriverSupport.h
Installing generic include file ../../../include/registryFunction.h
Installing generic include file ../../../include/registryCommon.h
Installing generic include file ../../../include/registryIocRegister.h
Installing generic include file ../../../include/rsrv.h
Installing generic include file ../../../include/rsrvIocRegister.h
Installing generated generic include file ../../../include/menuConvert.h
Installing generated generic include file ../../../include/menuAlarmSevr.h
Installing generated generic include file ../../../include/menuAlarmStat.h
Installing generated generic include file ../../../include/menuFtype.h
Installing generated generic include file ../../../include/menuIvoa.h
Installing generated generic include file ../../../include/menuOmsl.h
Installing generated generic include file ../../../include/menuPini.h
Installing generated generic include file ../../../include/menuPost.h
Installing generated generic include file ../../../include/menuPriority.h
Installing generated generic include file ../../../include/menuYesNo.h
Installing generated generic include file ../../../include/menuSimm.h
Installing generated generic include file ../../../include/menuScan.h
Installing generated generic include file ../../../include/dbCommon.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/bpt/makeBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/as/asDbLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/as/asCa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/as/asIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbLock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbAccess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbBkpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbChannel.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbFastLinkConv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbExtractArray.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbNotify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbScan.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/db_access.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/db_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/recGbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/callback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbCa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbCaTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/initHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/cvtBpt.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbChannelIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbSubscriptionIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbPutNotifyBlocker.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbContextReadNotifyCache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/templateInstances.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/chfPlugin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbUnitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/db/dbServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/dbStatic/dbStaticLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c dbYacc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/dbStatic/dbPvdLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/dbStatic/dbStaticRun.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/dbStatic/dbStaticIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c dbLoadTemplate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/dbtemplate/dbtoolsIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/misc/epicsRelease.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/misc/iocInit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/misc/miscIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/misc/dlload.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/misc/iocshRegisterCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/registry/registryRecordType.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/registry/registryDeviceSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/registry/registryDriverSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/registry/registryFunction.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/registry/registryCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/registry/registryIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I../../../src/ca/client     -c ../../../src/ioc/rsrv/caserverio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/rsrv/caservertask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/rsrv/camsgtask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I../../../src/ca/client     -c ../../../src/ioc/rsrv/camessage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/rsrv/cast_server.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/rsrv/online_notify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/rsrv/rsrvIocRegister.c
/usr/bin/ar -rc    libdbCore.a        asDbLib.o asCa.o asIocRegister.o dbLock.o dbAccess.o dbBkpt.o dbChannel.o dbConvert.o dbFastLinkConv.o dbExtractArray.o dbLink.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o dbIocRegister.o chfPlugin.o dbState.o dbUnitTest.o dbServer.o dbStaticLib.o dbYacc.o dbPvdLib.o dbStaticRun.o dbStaticIocRegister.o dbLoadTemplate.o dbtoolsIocRegister.o epicsRelease.o iocInit.o miscIocRegister.o dlload.o iocshRegisterCommon.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o registryCommon.o registryIocRegister.o caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o
/usr/bin/ranlib libdbCore.a
/usr/bin/g++ -o libdbCore.so.3.15.6 -shared -fPIC -Wl,-hlibdbCore.so.3.15.6 -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86>           -rdynamic -m32            asDbLib.o asCa.o asIocRegister.o dbLock.o dbAccess.o dbBkpt.o dbChannel.o dbConvert.o dbFastLinkConv.o dbExtractArray.o dbLink.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o dbIocRegister.o chfPlugin.o dbState.o dbUnitTest.o dbServer.o dbStaticLib.o dbYacc.o dbPvdLib.o dbStaticRun.o dbStaticIocRegister.o dbLoadTemplate.o dbtoolsIocRegister.o epicsRelease.o iocInit.o miscIocRegister.o dlload.o iocshRegisterCommon.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o registryCommon.o registryIocRegister.o caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libdbCore.so.3.15.6
ln -s libdbCore.so.3.15.6 ../../../lib/linux-x86/libdbCore.so
Installing library ../../../lib/linux-x86/libdbCore.a
/usr/bin/g++ -o makeBpt  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86>           -rdynamic -m32            makeBpt.o    -lCom
Installing created executable ../../../bin/linux-x86/makeBpt
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/makeBpt> ../../../src/ioc/bpt/bptTypeJdegC.data bptTypeJdegC.dbd
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/makeBpt> ../../../src/ioc/bpt/bptTypeJdegF.data bptTypeJdegF.dbd
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/makeBpt> ../../../src/ioc/bpt/bptTypeKdegC.data bptTypeKdegC.dbd
<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/makeBpt> ../../../src/ioc/bpt/bptTypeKdegF.data bptTypeKdegF.dbd
Creating dbd file menuGlobal.dbd
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/makeIncludeDbd.pl> menuAlarmSevr.dbd menuAlarmStat.dbd menuFtype.dbd menuIvoa.dbd menuOmsl.dbd menuPini.dbd menuPost.dbd menuPriority.dbd menuYesNo.dbd menuSimm.dbd menuGlobal.dbd
Installing created dbd file ../../../dbd/menuGlobal.dbd
mkdir ../../../dbd
Installing created dbd file ../../../dbd/bptTypeJdegC.dbd
Installing created dbd file ../../../dbd/bptTypeJdegF.dbd
Installing created dbd file ../../../dbd/bptTypeKdegC.dbd
Installing created dbd file ../../../dbd/bptTypeKdegF.dbd
Installing dbd file ../../../dbd/system.dbd
Installing dbd file ../../../dbd/dlload.dbd
Installing dbd file ../../../dbd/dbCore.dbd
Installing created dbd file ../../../dbd/menuConvert.dbd
Installing created dbd file ../../../dbd/menuAlarmSevr.dbd
Installing created dbd file ../../../dbd/menuAlarmStat.dbd
Installing created dbd file ../../../dbd/menuFtype.dbd
Installing created dbd file ../../../dbd/menuIvoa.dbd
Installing created dbd file ../../../dbd/menuOmsl.dbd
Installing dbd file ../../../dbd/menuPini.dbd
Installing dbd file ../../../dbd/menuPost.dbd
Installing dbd file ../../../dbd/menuPriority.dbd
Installing created dbd file ../../../dbd/menuYesNo.dbd
Installing created dbd file ../../../dbd/menuSimm.dbd
Installing created dbd file ../../../dbd/menuScan.dbd
Installing dbd file ../../../dbd/dbCommon.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/as/ascheck.c
/usr/bin/g++ -o ascheck  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86>           -rdynamic -m32            ascheck.o    -ldbCore -lca -lCom -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/ioc/dbtemplate/msi.cpp
../../../src/ioc/dbtemplate/msi.cpp: In function ���void makeSubstitutions(inputData*, MAC_HANDLE*, const char*)���:
../../../src/ioc/dbtemplate/msi.cpp:305: warning: comparison between signed and unsigned integer expressions
/usr/bin/g++ -o msi  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/lib/linux-x86>           -rdynamic -m32            msi.o    -lCom -lCom
Installing created executable ../../../bin/linux-x86/ascheck
Installing created executable ../../../bin/linux-x86/msi
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/dbdToHtml.pl>   -I. -I.. -I../O.Common -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../dbd -o menuConvert.html ../../../src/ioc/bpt/menuConvert.dbd.pod
Can't locate object method "html_charset" via package "Pod::Simple::XHTML" at <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/bin/linux-x86/dbdToHtml.pl> line 137.
../../../configure/RULES.Db:431: recipe for target '../O.Common/menuConvert.html' failed
make[3]: *** [../O.Common/menuConvert.html] Error 25
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/src/ioc/O.linux-x86'>
../../configure/RULES_ARCHS:58: recipe for target 'install.linux-x86' failed
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/src/ioc'>
../configure/RULES_DIRS:84: recipe for target 'ioc.install.linux-x86' failed
make[1]: *** [ioc.install.linux-x86] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/src'>
configure/RULES_DIRS:84: recipe for target 'src.install.linux-x86' failed
make: *** [src.install.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
Jenkins build is back to normal : epics-base-3.15-linux32 #414 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: EPICS-7 #223 Jenkins EPICS PSI via Core-talk
Next: Jenkins build is still unstable: epics-7.0 » linux64 #158 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : EPICS-7 #224 Jenkins EPICS PSI via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-linux32 #414 APS Jenkins via Core-talk
ANJ, 21 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
