2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 24 Oct 2019 17:54:00 -0000
Thanks Ben, I have applied your change to the 3.15 branch for 3.15.7
from where it will also be merged up for 7.0.3.1.
** Changed in: epics-base/3.15
       Status: In Progress => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1844537
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 3.15 series:
  Fix Committed
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  This was incorrectly documented for the boRecord. I just fixed that in
  the wiki.
  However, I see this as yet another arbitrary limitation.
  To lift that we need a small generalisation to how we treat constant
  links. A constant link just has to remember whether it has been
  processed before. The flag gets set by dbGetLink and the like and it
  gets reset after link initialisation (so we can change the "constant"
  using a CA put to the link field). If dbGetLink finds that the link is
  constant, then it converts the value from the string stored in the
  link, but only if it hasn't been processed before. This also means
  that we can deprecate recGblInitConstantLink because it is now
  subsumed by dbGetLink.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1844537/+subscriptions
[Bug 1844537] [NEW] OMSL doesn't work with constant DOL Ben Franksen via Core-talk
Prev: [Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL Andrew Johnson via Core-talk
Next: Build failed: epics-base base-7.0-346 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: [Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL Andrew Johnson via Core-talk
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
