Subject: |
[Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 31 Oct 2019 19:50:34 -0000 |
** Changed in: epics-base/7.0
Status: In Progress => Fix Committed
** Changed in: epics-base/3.15
Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1844537
Title:
Status in EPICS Base:
Fix Committed
Status in EPICS Base 3.15 series:
Fix Released
Status in EPICS Base 7.0 series:
Fix Committed
Bug description:
This was incorrectly documented for the boRecord. I just fixed that in
the wiki.
However, I see this as yet another arbitrary limitation.
To lift that we need a small generalisation to how we treat constant
links. A constant link just has to remember whether it has been
processed before. The flag gets set by dbGetLink and the like and it
gets reset after link initialisation (so we can change the "constant"
using a CA put to the link field). If dbGetLink finds that the link is
constant, then it converts the value from the string stored in the
link, but only if it hasn't been processed before. This also means
that we can deprecate recGblInitConstantLink because it is now
subsumed by dbGetLink.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1844537/+subscriptions
- [Bug 1844537] [NEW] OMSL doesn't work with constant DOL Ben Franksen via Core-talk
[Bug 1797634] Re: Broken shebang line in tap-to-junit-xml.pl Andrew Johnson via Core-talk
[Bug 1801145] Re: Improve place-holder record types Andrew Johnson via Core-talk
<2019>
2025
2026
[Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL Andrew Johnson via Core-talk
<2019>
2025
2026
