2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1815908] Re: casExpandRecvBuffer modifies the contents of the buffer
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 01 Nov 2019 20:19:26 -0000
** Changed in: epics-base
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1815908
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  For the following data base run in a SoftIOC (3.16.2):
  record(waveform, "PXD:H9999:D9:memoffsetdata_array:A:set"){
      field(FTVL, "UCHAR")
      field(NELM, "262144")
  record(waveform, "PXD:H9999:D9:memswdata_array:A:set"){
  the sequence of PV accesses created by this minimal sequence:
  // vi: ft=cpp
  program seqtest("")
  option +c; /* dont wait for db connections */
  option +r; /* make functions reentrant, multiple instances */
  option +d; /* toggle runtime debugging messages */
  option +W; /* extra warnings. */
  %%int i;
  unsigned char memswdata_array_set[16384];
  assign memswdata_array_set to "PXD:H9999:D9:memswdata_array:A:set";
  unsigned char memoffsetdata_array_set_small[32768];
  assign memoffsetdata_array_set_small to "PXD:H9999:D9:memoffsetdata_array:A:set";
  ss dhhseq_small {
    state init {
      entry {
        for( i = 0; i < sizeof memswdata_array_set; ++i ) memswdata_array_set[i] = i % 256;
        for( i = 0; i < sizeof memoffsetdata_array_set_small; ++i ) memoffsetdata_array_set_small[i] = 255 - i % 256;
        pvPut(memswdata_array_set, SYNC);
        pvPut(memoffsetdata_array_set_small, SYNC);
      when() {} state done
    state done {
          when () {} state done
  gives this error message on the softIOC side:
  CAS: request from 192.168.0.1:44512 => CAS: Missaligned protocol rejected
  CAS: Request from 192.168.0.1:44512 => cmmd=30720 cid=0x7800002c type=17023 count=0 postsize=44
  CAS: Request from 192.168.0.1:44512 =>   available=0x427f0000   N=0 paddr=(nil)
  CAS: forcing disconnect from 192.168.0.1:44512
  and a segfault on the sequence side.
  This report is (for now) about the softIOC.
  I can reliably produce this behavior on two different systems (SL7 and
  Debian) when both the softIOC and the sequence run on the same host.
  Communication is via the lo interface, so the data packets are large.
  During the second pvPut, the receive buffer is to be expanded a second
  time, and during this call, the contents change:
  before casExpandRecvBuffer
    start of buffer=00 13 ffffff80
  after casExpandRecvBuffer
    start of buffer=78 00 00
  I will try to follow this even further, but for now I'm creating this
  report to have a place to track my findings.
  Might there be a relation to https://bugs.launchpad.net/epics-
  base/+bug/1706703 ?
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1815908/+subscriptions
Prev: [Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME Andrew Johnson via Core-talk
Next: [Bug 1699229] Re: Joinable threads Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1815908] Re: casExpandRecvBuffer modifies the contents of the buffer mdavidsaver via Core-talk
Next: [Bug 1815864] Re: Assemblies fail to work on Windows Ralph Lange via Core-talk
ANJ, 01 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
