2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: checkRelease problem
From: "Zimoch Dirk \(PSI\) via Core-talk" <[email protected]>
Date: Thu, 7 Nov 2019 15:11:01 +0000
I have in my RELEASE.local:
SSCAN=
IPAC=
SNCSEQ=
(To overwrite settings in some SynApps modules.)
I get this error:
This application's RELEASE file(s) define
	IPAC =
after but not adjacent to
	SSCAN =
both of which resolve to /home/zimoch/git/calc/configure/O.linux-x86_64
Module definitions that share paths must be grouped together.
Either remove a definition, or move it to a line immediately
above or below the other(s).
Any non-module definitions belong in configure/CONFIG_SITE.
First of all, the definitions are adjacent. But more important, it should be OK to define an arbitrary number of module paths as empty strings.
Dirk
Re: checkRelease problem Johnson, Andrew N. via Core-talk
Prev: Base 3.14.12.5 make uninstall not removing bin or lib Baker, Keith (DLSLtd, RAL, LSCI) via Core-talk
Next: Re: checkRelease problem Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base 3.14.12.5 make uninstall not removing bin or lib Johnson, Andrew N. via Core-talk
ANJ, 14 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
