Subject: |
[Bug 1853168] Re: undefined reference to `clock_gettime' |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 20 Nov 2019 18:11:22 -0000 |
I fixed the ability to do MinGW DLL builds back in 2016
(6623cb01125a61ea) before the 3.14.12.6 and 3.15.5 releases, although
apparently some older versions of minGW won't necessarily work. Prior to
those releases our MinGW builds were configured with SHARED_LIBRARIES=NO
and STATIC_BUILD=YES but that commit removed those and since they we
have been doing DLL builds by default, unless you explicitly change the
settings in the CONFIG_SITE.linux-x86.win32-x86-mingw and/or
CONFIG_SITE.linux-x86.windows-x64-mingw files (the linux-x86_64 files
inherit from those).
My version of osiClockTime.obj is not importing clock_gettime for a 7.0
build:
tux% x86_64-w64-mingw32-nm osiClockTime.obj | grep clock_gettime
tux%
However the 3.15 build does:
U clock_gettime
This matches Michael's note about the
78b6312f493bbe02a37cc6f5fdcff38683d51236 commit (which evidently should
have been made on an earlier branch). However my 3.15 builds here still
work fine, so one of my MinGW libraries must be providing that symbol.
It isn't in any of the libraries that are being linked into libCom
though: -static-libgcc -static-libstdc++ -lws2_32 -ladvapi32 -luser32
However it is present in these libraries, neither of which my builds
explicitly link to:
libpthread.a
00000000000000a0 T clock_gettime
libpthread.dll.a
0000000000000000 T clock_gettime
0000000000000000 I __imp_clock_gettime
libwinpthread.a
libwinpthread.dll.a
Can we explain what's happening there?
One solution might be to back-port the
78b6312f493bbe02a37cc6f5fdcff38683d51236 commit to 3.15, but that won't
fix builds against older tagged releases. It would seem better to try
and fix this in the ci-scripts module if that's possible.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1853168
Title:
Status in EPICS Base:
New
Bug description:
I'm getting this linker error when building Base 3.15.6 with mingw:
/usr/bin/x86_64-w64-mingw32-g++ -o Com.dll -shared -Wl,--out-
implib,libCom.dll.a
-L/home/travis/.cache/base-R3.15.6/lib/windows-x64-mingw -m64
-static-libgcc -static-libstdc++ asLib.obj asTrapWrite.obj
bucketLib.obj postfix.obj calcPerform.obj cvtFast.obj resourceLib.obj
epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj ellSort.obj
envSubr.obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj
fdmgr.obj fdManager.obj freeListLib.obj gpHashLib.obj iocsh.obj
registry.obj libComRegister.obj iocLog.obj logClient.obj macCore.obj
macEnv.obj macUtil.obj alarmString.obj aToIPAddr.obj adjustment.obj
cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj
epicsString.obj truncateFile.obj ipAddrToAsciiAsynchronous.obj
epicsUnitTest.obj epicsThread.obj epicsMutex.obj epicsEvent.obj
epicsTime.obj epicsMessageQueue.obj epicsMath.obj epicsAtomicOSD.obj
epicsGeneralTime.obj osiClockTime.obj osdSock.obj osdSockAddrReuse.obj
osiSock.obj systemCallIntMech.obj epicsSocketConvertErrnoToString.obj
osdAssert.obj osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj
osdSignal.obj osdEnv.obj epicsReadline.obj epicsTempFile.obj
epicsStdio.obj osdStdio.obj osdThread.obj osdThreadExtra.obj
osdThreadHooks.obj osdMutex.obj osdSpin.obj osdEvent.obj osdTime.obj
osdProcess.obj osdNetIntf.obj osdMessageQueue.obj devLibVME.obj
devLibVMEOSD.obj epicsStackTrace.obj osdBackTrace.obj osdFindAddr.obj
poolJob.obj threadPool.obj epicsRingPointer.obj epicsRingBytes.obj
taskwd.obj epicsTimer.obj timer.obj timerQueue.obj
timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj
yajl.obj yajl_alloc.obj yajl_buf.obj yajl_encode.obj yajl_gen.obj
yajl_lex.obj yajl_parser.obj epicsGetopt.obj setThreadName.obj
forceBadAllocException.obj Com.coff -lws2_32 -ladvapi32 -luser32
-lws2_32
osiClockTime.obj:osiClockTime.c:(.text+0xb4): undefined reference to
`clock_gettime'
osiClockTime.obj:osiClockTime.c:(.text+0x33b): undefined reference to
`clock_gettime'
collect2: error: ld returned 1 exit status
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1853168/+subscriptions
- [Bug 1853168] [NEW] undefined reference to `clock_gettime' Dirk Zimoch via Core-talk
[Bug 1853168] Re: undefined reference to `clock_gettime' mdavidsaver via Core-talk
[Bug 1853168] Re: undefined reference to `clock_gettime' Ralph Lange via Core-talk
<2019>
2025
2026
<2019>
2025
2026
