2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Tue, 26 Nov 2019 00:58:25 -0000
> I don't see any way to set a prefix for logging to an external log-server without also enabling errlogToSyslog()
Well yes, I removed this as requested...
> become a similar command that must appear in st.cmd
Unfortunately this is exactly what I'm trying to avoid.
My motivating use case is a sysadmin wishing to setup/change logging for all IOCs on a host.  Defining an environment variable is a common way for an init script (or systemd unit) to communicate this.  Of course, this can already be accomplished by capturing stdout/err (a la procServ).  Though procServ isn't used as often as (I think) it should be.
> I'm not convinced we have the prefix logic right — sorry!
Shall I remove the interconnection with iocLogPrefix() ?
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/373098
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 mdavidsaver via Core-talk
Prev: Build failed: epics-base base-libcom-api-364 AppVeyor via Core-talk
Next: Build failed: epics-base base-integration-365 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 Martin Konrad via Core-talk
ANJ, 26 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
