2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0
From: Martin Konrad via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Tue, 26 Nov 2019 16:29:17 -0000
Another thought on environment variables vs. commands in st.cmd: At FRIB our IT administrators are running our log servers. They know best which host/port/protocol should be used. They have the tools to provide these settings consistently as environment variables/config files on all machines. I would thus suggest to make it possible for IT to be in control of these settings while IOC engineers are in control of which database files are loaded etc.
We are currently doing stuff like
caPutLogInit("${EPICS_PUT_LOG_INET}:${EPICS_PUT_LOG_PORT}", 1)
to ensure our sysadmins are in control. This works but it would be easier if the IOC would pick up logging settings directly from environment variables.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/373098
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 mdavidsaver via Core-talk
Prev: Build failed: epics-base base-errlog2syslog-367 AppVeyor via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 26 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
