2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
Date: Sat, 30 Nov 2019 07:14:51 -0000
Added documentation to the Release Notes including how to modify an external device support that must remain compatible with older versions of Base. Rather than using one of the new and probably unfamiliar record types for that I converted the ai record and all the internal device supports that use it.
There is an unfortunate issue with the lso, lsi and printf records which were already publishing their dsets, so they need a slightly different approach to remain compatible with older Base versions, which I also showed. The alternative would have been to rename the dset for these record types, but I didn't want to break the naming pattern if I could avoid it.
I have tested these approaches with Kay's ether_ip driver, and will send him a PR for that code once this branch gets merged.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/375934
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 Andrew Johnson via Core-talk
Prev: Build completed: epics-base base-3.15-285 AppVeyor via Core-talk
Next: Re: lsi record for more than 40 characters doesn't work Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 Ralph Lange via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 Ralph Lange via Core-talk
ANJ, 04 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
