2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: lsi record for more than 40 characters doesn't work
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: dmnr infn <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 1 Dec 2019 05:37:11 +0000
How are you reading the lsi value and determining that it only has 40 characters?
Please try doing ‘caget -S RF:getString.VAL$’
If you do ‘cainfo RF:getString’ it will tell you that the VAL field is a normal DBF_STRING type, which can only transport up to 40 characters. You have to use the $ field modifier to gain access to the rest of the string, so ‘cainfo RF:getString.$’ will show the field as an array of 80 characters.
I don’t use StreamDevice myself but I’m assuming that it properly supports the lsi record. However I suspect trying to read your string at 5Hz as your SCAN field currently shows is probably not a good idea and may cause other problems.
- Andrew
Sent from my iPad
> On Nov 30, 2019, at 10:44 PM, dmnr infn via Tech-talk <[email protected]> wrote:
> Hi all,
> I have a .db e .proto made in this way:
> .db
> record(lsi, "RF:getString")
>     field(DESC, "String more than 40 chars")
>     field(SIZV, "80")
>     field(INP, "@MDO.proto getString L0")
>     field(SCAN, ".2 second")
> .proto
> getString {
>     out "STT?";
>     in "%s";
> I want to get a String that is more than 40 characters, and I use a lsi record but I got always 40 chars.
> There is something wrong in my code?
> Thank you
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: lsi record for more than 40 characters doesn't work Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Build completed: epics-base base-3.15-285 AppVeyor via Core-talk
ANJ, 01 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
