Your database and protocol look fine. Why do you think you are only getting 40 characters? Have you checked the lsi record's contents from the iocShell? Have you checked its LEN field? Have you switched on debugging for StreamDevice and/or ASYN?
If you are reading your string over Channel Access, note that the CA string type is limited to 40 characters. For longer strings, your application will have to fetch the value as an array of characters (by adding the '$' tag to the channel name) and convert that array to a string. The command line 'caget' for your lsi record would be: caget -S RF:getString.VAL$
Cheers, ~Ralph
Hi all, I have a .db e .proto made in this way:
.db record(lsi, "RF:getString") { field(DESC, "String more than 40 chars") field(SIZV, "80") field(INP, "@MDO.proto getString L0") field(SCAN, ".2 second") }
.proto getString { out "STT?"; in "%s"; }
I want to get a String that is more than 40 characters, and I use a lsi record but I got always 40 chars. There is something wrong in my code? Thank you
Re: lsi record for more than 40 characters doesn't work Johnson, Andrew N. via Core-talk
Re: lsi record for more than 40 characters doesn't work Eric Norum via Core-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 02 Dec 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
