Subject: |
Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security |
"J. Lewis Muir via Core-talk" <[email protected]> |
To: |
Goetz Pfeiffer <[email protected]> |
Cc: |
[email protected] |
Date: |
Fri, 6 Dec 2019 15:48:08 -0600 |
On 12/06, Goetz Pfeiffer via Core-talk wrote:
> I would like to hear your comments and suggestions regarding this topic.
> The changes consist of three parts:
> - Define networks to be ignored by servers with environment variable
> EPICS_CAS_IGNORE_NET_LIST
What about just using EPICS_CAS_IGNORE_ADDR_LIST but extending its
syntax to allow specifying networks (e.g., 192.168.12.0/24)? Or you
could extend the syntax to allow specifying a range with a ".." literal
(e.g., 192.168.12.0..255)?
It seems a bit weird to have two separate variables: one for addresses
and one for networks. You're still trying to specify a list of
addresses, you're just wanting to introduce the ability to specify a
range of addresses in a short form.
> - Define networks to be ignored by clients with environment variable
> EPICS_CA_IGNORE_NET_LIST
Similar comment here as above. What about just adding
EPICS_CA_IGNORE_ADDR_LIST instead, and using it like
EPICS_CAS_IGNORE_ADDR_LIST?
Lewis
- Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Goetz Pfeiffer via Core-talk
- Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Goetz Pfeiffer via Core-talk
Build failed: epics-base base-fix/c99math-287 AppVeyor via Core-talk
Build failed: EPICS Base base-7.0-489 AppVeyor via Core-talk
<2019>
2025
2026
<2019>
2025
2026
