2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security
From: Goetz Pfeiffer via Core-talk <[email protected]>
To: <[email protected]>
Date: Fri, 6 Dec 2019 17:09:26 +0100
Hello,
I would like to propose changes to EPICS Base, the portable channel access
server and the channel access gateway.
I have already implemented and tested these changes for version 3.15 and 7.0
of the EPICS base and the most recent versions of the portable channel access
server PCAS and the channel access gateway.
I would like to hear your comments and suggestions regarding this topic.
The changes consist of three parts:
- Define networks to be ignored by servers with environment variable
  EPICS_CAS_IGNORE_NET_LIST
- Define networks to be ignored by clients with environment variable
  EPICS_CA_IGNORE_NET_LIST
- Extend channel access security with IP access groups that define the IP
  address a client must have
Here are the details:
Define networks to be ignored by servers, EPICS_CAS_IGNORE_NET_LIST
This environment variable is comparable to to EPICS_CAS_IGNORE_ADDR_LIST since
It causes a channel access server to ignore requests from some clients.
With EPICS_CAS_IGNORE_ADDR_LIST you specify a list of host names or IP
addresses. This works fine but you have to specify a very long string if you
need to ignore addresses of a whole subnet with hundreds of IP addresses.
With EPICS_CAS_IGNORE_NET_LIST you can specify one or more subnets to ignore.
The subnet specifications in EPICS_CAS_IGNORE_NET_LIST must be separated with
spaces.
Three forms of subnet specifications are supported:
- CIDR notation, example: 192.168.12.0/24
- Address and mask notation, example: 192.168.12.0:255.255.255.0
- Single IP address, example: 192.168.12.10
Example
In order to ignore hosts from 192.168.22.0/24, EPICS_CAS_IGNORE_ADDR_LIST
would need 254 entries like here::
  EPICS_CAS_IGNORE_ADDR_LIST="192.168.22.1 192.168.22.2 192.168.22.3 \
  192.168.22.4 192.168.22.5 192.168.22.6 192.168.22.7 192.168.22.8 \
  192.168.22.250 192.168.22.251 192.168.22.252 192.168.22.253 192.168.22.254
With EPICS_CAS_IGNORE_NET_LIST the same can be archived like this::
  EPICS_CAS_IGNORE_NET_LIST=192.168.22.0/24
Also, the check for a valid address is quicker with the new variable, instead
of 254 comparisons we have two AND operations and one comparison.
Usage in channel access gateway configuration
The configuration of exporting channel access gateways at the
Helmholtz-Zentrum Berlin as it is shown here:
  https://www-csr.bessy.de/control/ca-net-gateways
is made much simpler, since we always have to ignore a complete subnet. For
now, we just had to ignore class C subnets, bigger subnets would be unusable
with EPICS_CAS_IGNORE_ADDR_LIST.
Changes in the software
Both, the "rsrv" server and the "PCAS" server were changed for this.
A patch exists for EPICS Base 3.15 and EPICS Base 7 and PCAS.
The generated file epicsVersion.h has a new macro,
EPICS_HAS_CAS_IGNORE_NET_LIST, that is defined with this patch. This enables
programs like the channel access gateway to support both, an EPICS Base with
and without this patch.
Define networks to be ignored by clients, EPICS_CA_IGNORE_NET_LIST
This variable introduces the concept of ignoring certain hosts to the channel
access client. Hosts whose IP address match one of the subnets specified
with EPICS_CA_IGNORE_NET_LIST are ignored.
This provides a possible solution for "duplicate PV" errors when a process
variable of the same name is presented by more than one server.
Although this variable can be used for all channel access clients, it is
particularly useful for the channel access gateway. With this there is an easy
way to let the gateway ignore certain channel access servers.
The subnet specifications in EPICS_CA_IGNORE_NET_LIST must be separated with
spaces.
The channel access client library in EPICS Base was changed for this.
A patch exists for EPICS Base 3.15 and EPICS Base 7.
EPICS_HAS_CA_IGNORE_NET_LIST, that is defined with this patch. This enables
Access security with IP access groups
Access security currently allows a channel access server to check the host
name and the user name of a client that wants to connect.
However, the information of what host and what user wants to connect is
provided by the channel access library of the client and is not necessarily
reliable.
Another problem is that the host name the channel access client library
provides is not the fully qualified domain name, which can be assumed to be
unique, but the short host name as it is configured on the client's system.
With this patch, channel access security can be configured to check the IP
address of the client.
The definition of the access security configuration file was extended for
this. An IP access group, IPAG, was added to the existing host access group,
HAG, and the user access group UAG.
IP access groups can be added to an existing access security configuration or
can, for example, replace host access groups.
The changes in access security are backwards compatible, old access security
configuration files are still valid.
The access security library in EPICS Base was changed for this. Changes were
also necessary in PCAS and the channel access gateway. A patch exists for
The generated file epicsVersion.h has a new macro, EPICS_HAS_AS_IPAG, that is
defined with this patch. This enables programs like the channel access gateway
to support both, an EPICS Base with and without this patch.
Verification and tests
I compiled my patches for linux-x86_64, windows-x64 and RTEMS-mvme2100 (RTEMS
4.9). I ensured that no additional critical compiler warnings were produced.
I tested the function with softiocs, the "cainfo" utility and the channel
access gateway on Linux (Fedora 30).
Repositories with patches
The repositories with my patches can be found here:
Launchpad (only EPICS base)
https://code.launchpad.net/~goetzpf/+git/epics-ip-ignore-as-IPAG-patches_base_3.15
https://code.launchpad.net/~goetzpf/+git/epics-ip-ignore-as-IPAG-patches_base_7
Github
https://github.com/goetzpf/epics-base/tree/ip-ignore-as-IPAG-3.15
https://github.com/goetzpf/epics-base/tree/ip-ignore-as-IPAG-7.0
https://github.com/goetzpf/pcas/tree/ip-ignore-as-IPAG
https://github.com/goetzpf/ca-gateway/tree/ip-ignore-as-IPAG
I would appreciate your comments, suggestions or improvements.
Greetings,
  Goetz Pfeiffer
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Ralph Lange via Core-talk
Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security J. Lewis Muir via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-win64-test #264 APS Jenkins via Core-talk
Next: Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-win64-test #265 APS Jenkins via Core-talk
ANJ, 06 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
